Anker Soundcore Flare Mini Waterproof Outer Shell Replacement
    1. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Bottom Cover: step 1, image 1 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Bottom Cover: step 1, image 2 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Bottom Cover: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • The rubber cover of the speaker is glued down.
      • Use precision tweezers to peel the rubber cover off of the bottom of the speaker.
      Ask FixBot
    2. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 2, image 1 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 2, image 2 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 2, image 3 of 3
      • Remove six 10 mm screws holding the plastic cover in place using a Phillips #1 screwdriver.
      • Use your hand to pull the plastic cover off the bottom of the speaker.
      Ask FixBot
    1. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Motherboard: step 3, image 1 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Motherboard: step 3, image 2 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Motherboard: step 3, image 3 of 3
      • Remove the single 10 mm screw holding the motherboard in place using a Phillips #1 screwdriver.
      • Lift the motherboard up.
      • The motherboard is still attached to several wires underneath.
      Ask FixBot
    2. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 4, image 1 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 4, image 2 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 4, image 3 of 3
      Buy
      • Use precision tweezers to firmly grasp the five power connectors and detach them from the back of the motherboard.
      • When removing the power connectors, do not pull the wires themselves.
      • Remove the motherboard from the speaker.
      Ask FixBot
    1. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Waterproof Outer Shell: step 5, image 1 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Waterproof Outer Shell: step 5, image 2 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Waterproof Outer Shell: step 5, image 3 of 3
      • Remove the four 11 mm screws from the white plastic cover using a Phillips #1 screwdriver.
      • Remove the white plastic cover from the speaker.
      Ask FixBot
    2. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 6, image 1 of 2 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 6, image 2 of 2
      • Remove the other four 11 mm screws holding the outer shell in place with a Phillips #1 screwdriver.
      Ask FixBot
    3. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 7, image 1 of 1
      • Pull the charging port away from the side of the speaker.
      Ask FixBot
    4. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 8, image 1 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 8, image 2 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 8, image 3 of 3
      • Use a spudger to loosen the cover from the inner components of the speaker.
      • Slide the cover completely off.
      • One wire will still be connected to the shell.
      Ask FixBot
1 Guide Comment
Where can I purchase the outer shell? Share link please
Arsam Sohail - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 25
All Time: 1,106
