Anker Soundcore Flare Mini Motherboard Replacement
  1. Anker Soundcore Flare Mini Motherboard Replacement, Bottom Cover: step 1, image 1 of 3 Anker Soundcore Flare Mini Motherboard Replacement, Bottom Cover: step 1, image 2 of 3 Anker Soundcore Flare Mini Motherboard Replacement, Bottom Cover: step 1, image 3 of 3
    Tool used on this step:
    Buy
    • The rubber cover of the speaker is glued down.
    • Use precision tweezers to peel the rubber cover off of the bottom of the speaker.
    Ask FixBot
  2. Anker Soundcore Flare Mini Motherboard Replacement: step 2, image 1 of 3 Anker Soundcore Flare Mini Motherboard Replacement: step 2, image 2 of 3 Anker Soundcore Flare Mini Motherboard Replacement: step 2, image 3 of 3
    • Remove six 10 mm screws holding the plastic cover in place using a Phillips #1 screwdriver.
    • Use your hand to pull the plastic cover off the bottom of the speaker.
    Ask FixBot
  3. Anker Soundcore Flare Mini Motherboard Replacement, Motherboard: step 3, image 1 of 3 Anker Soundcore Flare Mini Motherboard Replacement, Motherboard: step 3, image 2 of 3 Anker Soundcore Flare Mini Motherboard Replacement, Motherboard: step 3, image 3 of 3
    • Remove the single 10 mm screw holding the motherboard in place using a Phillips #1 screwdriver.
    • Lift the motherboard up.
    • The motherboard is still attached to several wires underneath.
    Ask FixBot
  4. Anker Soundcore Flare Mini Motherboard Replacement: step 4, image 1 of 3 Anker Soundcore Flare Mini Motherboard Replacement: step 4, image 2 of 3 Anker Soundcore Flare Mini Motherboard Replacement: step 4, image 3 of 3
    Buy
    • Use precision tweezers to firmly grasp the five power connectors and detach them from the back of the motherboard.
    • When removing the power connectors, do not pull the wires themselves.
    • Remove the motherboard from the speaker.
    Ask FixBot
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 40
All Time: 1,647
