Anker Soundcore Flare Mini Bottom Cover Replacement
    1. Anker Soundcore Flare Mini Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 3 Anker Soundcore Flare Mini Bottom Cover Replacement, Bottom Cover: step 1, image 2 of 3 Anker Soundcore Flare Mini Bottom Cover Replacement, Bottom Cover: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • The rubber cover of the speaker is glued down.
      • Use precision tweezers to peel the rubber cover off of the bottom of the speaker.
      Ask FixBot
    2. Anker Soundcore Flare Mini Bottom Cover Replacement: step 2, image 1 of 3 Anker Soundcore Flare Mini Bottom Cover Replacement: step 2, image 2 of 3 Anker Soundcore Flare Mini Bottom Cover Replacement: step 2, image 3 of 3
      • Remove six 10 mm screws holding the plastic cover in place using a Phillips #1 screwdriver.
      • Use your hand to pull the plastic cover off the bottom of the speaker.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 47
All Time: 1,147
