Anker Soundcore Boost A3145 Repair Outer Shell Replacement
    1. Anker Soundcore Boost A3145 Repair Outer Shell Replacement, Base: step 1, image 1 of 2 Anker Soundcore Boost A3145 Repair Outer Shell Replacement, Base: step 1, image 2 of 2
      • Insert a spudger between the base of the speaker and its body.
      • Along the seams of the base, begin prying at the hooks until you hear a “click”.
      • Once you get a slight lift, slowly glide the spudger throughout the base to unlatch all the hooks.
      Ask FixBot
    2. Anker Soundcore Boost A3145 Repair Outer Shell Replacement: step 2, image 1 of 2 Anker Soundcore Boost A3145 Repair Outer Shell Replacement: step 2, image 2 of 2
      • Using the spudger, dig at the center of the speaker to pry at the adhesive keeping the remaining base attached (Utilize the image in Step 3 as a reference for where the adhesive is).
      • Some sort of heating element may help in softening the adhesive, however both excessive heat and moisture are not recommended!
      Ask FixBot
    3. Anker Soundcore Boost A3145 Repair Outer Shell Replacement: step 3, image 1 of 1
      • Lift the old base up and replace the new base, relatching the new base with a “click” for each hook.
      • It is recommended that any old adhesive be cleaned off and replaced prior to reinstallation.
      Ask FixBot
    1. Anker Soundcore Boost A3145 Repair Outer Shell Replacement, Battery: step 4, image 1 of 2 Anker Soundcore Boost A3145 Repair Outer Shell Replacement, Battery: step 4, image 2 of 2
      • Remove the eight 9 mm Phillips #0 screws from around the base plate.
      • Remove the six 6.3 mm Phillips #0 screws from around the battery cap.
      • Some screws may be underneath some adhesive from the speaker’s base.
      • Use a spudger to pry up the base plate.
      Ask FixBot
    2. Anker Soundcore Boost A3145 Repair Outer Shell Replacement: step 5, image 1 of 3 Anker Soundcore Boost A3145 Repair Outer Shell Replacement: step 5, image 2 of 3 Anker Soundcore Boost A3145 Repair Outer Shell Replacement: step 5, image 3 of 3
      • Gently pry the battery connector directly out of its socket.
      Ask FixBot
    3. Anker Soundcore Boost A3145 Repair Outer Shell Replacement: step 6, image 1 of 3 Anker Soundcore Boost A3145 Repair Outer Shell Replacement: step 6, image 2 of 3 Anker Soundcore Boost A3145 Repair Outer Shell Replacement: step 6, image 3 of 3
      • Take off the battery cover.
      • Using a spudger that's ESD-safe, remove the battery from the chassis.
      Ask FixBot
    1. Anker Soundcore Boost A3145 Repair Outer Shell Replacement, Outer Shell: step 7, image 1 of 1
      • Remove the six 7.6 mm Phillips #0 screws that secure the outer shell.
      • The screws in were hidden with rubber. You will need a spudger to pry them open to see the screws.
      Ask FixBot
    2. Anker Soundcore Boost A3145 Repair Outer Shell Replacement: step 8, image 1 of 2 Anker Soundcore Boost A3145 Repair Outer Shell Replacement: step 8, image 2 of 2
      • Use a sharp or thin tool to separate the corners from the main portion of the speaker.
      Ask FixBot
    3. Anker Soundcore Boost A3145 Repair Outer Shell Replacement: step 9, image 1 of 2 Anker Soundcore Boost A3145 Repair Outer Shell Replacement: step 9, image 2 of 2
      • Use your fingers to open both sides, then push forward and remove the outer shell from the main portion of the speaker.
      • Do not open both sides too wide, or it could break in the middle.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 49
All Time: 185
