Introduction
Throughout your continued use of your speaker’s lifespan, you may notice it not lasting quite as long as it used to, taking significantly longer to charge, or not charging at all. This may indicate the need for a charging port replacement. This guide will demonstrate the proper procedures for replacing your Anker Soundcore Boost A3145’s charging port. It is important to note that your device should be fully powered off and unplugged before proceeding with the repair.
Insert a spudger between the base of the speaker and its body.
Along the seams of the base, begin prying at the hooks until you hear a “click”.
Once you get a slight lift, slowly glide the spudger throughout the base to unlatch all the hooks.
Remove the eight 9 mm Phillips #0 screws from around the base plate.
Remove the six 6.3 mm Phillips #0 screws from around the battery cap.
Use a spudger to pry up the base plate.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
2 other people completed this guide.
