Anker Soundcore Boost A3145 Base Replacement
    1. Anker Soundcore Boost A3145 Base Replacement, Base: step 1, image 1 of 2 Anker Soundcore Boost A3145 Base Replacement, Base: step 1, image 2 of 2
      • Insert a spudger between the base of the speaker and its body.
      • Along the seams of the base, begin prying at the hooks until you hear a “click”.
      • Once you get a slight lift, slowly glide the spudger throughout the base to unlatch all the hooks.
      Ask FixBot
    2. Anker Soundcore Boost A3145 Base Replacement: step 2, image 1 of 2 Anker Soundcore Boost A3145 Base Replacement: step 2, image 2 of 2
      • Using the spudger, dig at the center of the speaker to pry at the adhesive keeping the remaining base attached (Utilize the image in Step 3 as a reference for where the adhesive is).
      • Some sort of heating element may help in softening the adhesive, however both excessive heat and moisture are not recommended!
      Ask FixBot
    3. Anker Soundcore Boost A3145 Base Replacement: step 3, image 1 of 1
      • Lift the old base up and replace the new base, relatching the new base with a “click” for each hook.
      • It is recommended that any old adhesive be cleaned off and replaced prior to reinstallation.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 29
All Time: 128
