This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Anker Soundcore Boost (A3145) replacement battery replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
26
Past 30 Days:
144
All Time:
600
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This guide shows the steps for "Anker Soundcore Boost (A3145) replacement battery replacement."
    1. Anker Soundcore Boost (A3145) replacement battery replacement, Opening the box: step 1, image 1 of 3 Anker Soundcore Boost (A3145) replacement battery replacement, Opening the box: step 1, image 2 of 3 Anker Soundcore Boost (A3145) replacement battery replacement, Opening the box: step 1, image 3 of 3
      • First, remove the bottom of the box from the side with the charging ports. It is secured by four clips on each side and fixed with double-sided adhesive tape. You can remove it by hand, optionally using a plastic card or plastic opening tool.
      Ask FixBot
    2. Anker Soundcore Boost (A3145) replacement battery replacement, Unscrew the plate: step 2, image 1 of 3 Anker Soundcore Boost (A3145) replacement battery replacement, Unscrew the plate: step 2, image 2 of 3 Anker Soundcore Boost (A3145) replacement battery replacement, Unscrew the plate: step 2, image 3 of 3
      • Underneath the base plate, there is a plate that is secured with 8 screws.
      • Caution! The replacement battery is attached to this plate and connected to the motherboard via a short cable, so only open it carefully.
      Ask FixBot
    3. Anker Soundcore Boost (A3145) replacement battery replacement, Disconnect and remove the replacement battery: step 3, image 1 of 3 Anker Soundcore Boost (A3145) replacement battery replacement, Disconnect and remove the replacement battery: step 3, image 2 of 3 Anker Soundcore Boost (A3145) replacement battery replacement, Disconnect and remove the replacement battery: step 3, image 3 of 3
      • Disconnect the replacement battery connector from the motherboard.
      • Then, unscrew the two screws on the right and left of the replacement battery pack and remove the replacement battery pack from the plate.
      Ask FixBot
    4. Anker Soundcore Boost (A3145) replacement battery replacement, Remove the replacement battery from the housing: step 4, image 1 of 3 Anker Soundcore Boost (A3145) replacement battery replacement, Remove the replacement battery from the housing: step 4, image 2 of 3 Anker Soundcore Boost (A3145) replacement battery replacement, Remove the replacement battery from the housing: step 4, image 3 of 3
      • Now the replacement batteries must be removed from the housing. Again, be CAREFUL here! The cable is a little difficult to thread through here.
      • And you're done; for those replacing the whole replacement battery, simply reinstall the new replacement battery in reverse order. I am rebuilding the battery pack from two 18650 replacement batteries:
      Ask FixBot
    5. Anker Soundcore Boost (A3145) replacement battery replacement, Optional: Repopulate the battery pack with new replacement batteries: step 5, image 1 of 3 Anker Soundcore Boost (A3145) replacement battery replacement, Optional: Repopulate the battery pack with new replacement batteries: step 5, image 2 of 3 Anker Soundcore Boost (A3145) replacement battery replacement, Optional: Repopulate the battery pack with new replacement batteries: step 5, image 3 of 3
      • If you want to repopulate the battery pack with new replacement batteries instead of replacing the entire battery pack, you can build your own pack using two 18650 replacement batteries.
      • After you have glued the two cells with the cables into a pack, place the two 18650 replacement batteries back onto the protection board and align the connection tabs as shown in the photos.
      Ask FixBot
Follow the steps in reverse order to reassemble your device.
MaximusVII
121 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 144
All Time: 600
