Anker Soundcore Boom 2 Battery Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
13
Past 7 Days:
84
Past 30 Days:
321
All Time:
2,895
Comments: 7
1 comment on steps, 6 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide applies to the Anker Soundcore Boom 2 Speaker, model number A3138.
The following replacement guide covers how to remove and replace the battery of the device. This part powers the entire device when it's disconnected from a power outlet.
Signs that it's time to replace the battery are the device dying early and power related issues.
Tools
    1. Anker Soundcore Boom 2 Battery Replacement, Front Panel: step 1, image 1 of 2 Anker Soundcore Boom 2 Battery Replacement, Front Panel: step 1, image 2 of 2
      • Use a metal spudger to gently pry the front panel off of the speaker.
      • Start with the top of the panel, pressing in and down on the middle of the top of the panel to release the tab holding it in place.
      Ask FixBot
    2. Anker Soundcore Boom 2 Battery Replacement: step 2, image 1 of 1
      • Continue around edge of the front panel, releasing each tab until the panel is loose and comes free.
      • Some speaker models have a strong adhesive around the edge of the panel that may require heat or glue-remover to loosen.
      Ask FixBot
    1. Anker Soundcore Boom 2 Battery Replacement, Speaker Head: step 3, image 1 of 2 Anker Soundcore Boom 2 Battery Replacement, Speaker Head: step 3, image 2 of 2
      • Use a Phillips head screwdriver to remove the 8 screws surrounding the speaker head on the front facing panel.
      Ask FixBot
    2. Anker Soundcore Boom 2 Battery Replacement: step 4, image 1 of 1
      • Use a spudger to remove the top plate off of the handle.
      Ask FixBot
    3. Anker Soundcore Boom 2 Battery Replacement: step 5, image 1 of 2 Anker Soundcore Boom 2 Battery Replacement: step 5, image 2 of 2
      • Remove the 3 screws in the handle with a Phillips head screwdriver.
      Ask FixBot
    4. Anker Soundcore Boom 2 Battery Replacement: step 6, image 1 of 2 Anker Soundcore Boom 2 Battery Replacement: step 6, image 2 of 2
      • Use a spudger to separate the front facing panel from the rear facing panel.
      • Follow the seam all the way around the device, prying gently until a gap appears before moving further along.
      • This will split the device from front and back.
      Ask FixBot
    5. Anker Soundcore Boom 2 Battery Replacement: step 7, image 1 of 1
      • Use pliers to disconnect the speaker head from the motherboard.
      Ask FixBot
    6. Anker Soundcore Boom 2 Battery Replacement: step 8, image 1 of 1
      • Use a Phillips head screwdriver to remove the 6 screws around the backside of the speaker head.
      Ask FixBot
    7. Anker Soundcore Boom 2 Battery Replacement: step 9, image 1 of 1
      • Remove the speaker head from the front facing panel.
      Ask FixBot
    1. Anker Soundcore Boom 2 Battery Replacement, Button Panel: step 10, image 1 of 1
      • Use your fingers to gently disconnect the motherboard ribbon cable from the button panel.
      Ask FixBot
    2. Anker Soundcore Boom 2 Battery Replacement: step 11, image 1 of 1
      • Use pliers or tweezers to disconnect the microphone cable and the button wire from the motherboard.
      Ask FixBot
    3. Anker Soundcore Boom 2 Battery Replacement: step 12, image 1 of 2 Anker Soundcore Boom 2 Battery Replacement: step 12, image 2 of 2
      • Use a Phillips head screwdriver to remove the 8 screws from the button panel.
      • Carefully slide the button panel out of place.
      Ask FixBot
    1. Anker Soundcore Boom 2 Battery Replacement, Waterproof Gasket: step 13, image 1 of 2 Anker Soundcore Boom 2 Battery Replacement, Waterproof Gasket: step 13, image 2 of 2
      • With the device pulled apart and the wires to the speaker head and button panel disconnected, remove the gasket from around the edge of the internal compartment.
      Ask FixBot
    1. Anker Soundcore Boom 2 Battery Replacement, Battery: step 14, image 1 of 1
      • Use pliers or tweezers to disconnect the battery from the motherboard.
      Ask FixBot
    2. Anker Soundcore Boom 2 Battery Replacement: step 15, image 1 of 1
      • Use a Phillips head screwdriver to remove the 6 screws that hold the battery in place.
      Ask FixBot
    3. Anker Soundcore Boom 2 Battery Replacement: step 16, image 1 of 1
      • Remove the battery from the rear facing panel.
      Ask FixBot
2 other people completed this guide.
Cole Enos-Waffles
665 Reputation
5 Guides authored
6 Guide Comments
Where can I find the Li-Ion battery for the Anker Soundcore Boom 2?
Terry - Reply Share
I have the same question have you had any response email me tlcjlw@sbcglobal,net I tore my unit apart thinking I could get a battery with no luck even contacted anker they say there is no replacement.
John Wall - Reply Share
Have you had any response to your battery question?
I just returned mine and got a refund.
Ashwin Campbell - Reply Share
Bonjour,
Google on my phone lets me take a picture of things and then search. These batteries are not too hard to find the on internet. The difficult part is you may need to use a “point soldering” machine to attach the battery. I found a computer repair club to help me replace batteries in Bose speaker and a drill.
Ryan Krida - Reply Share
Past 24 Hours: 13
Past 7 Days: 84
Past 30 Days: 321
All Time: 2,895
