Anker Soundcore 3 Speaker Replacement
  1. Anker Soundcore 3 Speaker Replacement, Speaker: step 1, image 1 of 2 Anker Soundcore 3 Speaker Replacement, Speaker: step 1, image 2 of 2
    • Insert the metal spudger in between the speaker's front panel and casing
    • Continuously pry around the edges of the casing; you should hear the glue start to separate from the front panel before the two parts separate.
    Ask FixBot
  2. Anker Soundcore 3 Speaker Replacement: step 2, image 1 of 3 Anker Soundcore 3 Speaker Replacement: step 2, image 2 of 3 Anker Soundcore 3 Speaker Replacement: step 2, image 3 of 3
    • Remove 8 of the 10 mm screws from the speaker panel using a Phillips #0 screwdriver.
    • Using the metal spudger, gently pry at the outer-edges of the speaker to remove the rubber/plastic panel that sits above the motherboard.
    • Grip and disconnect the cable connector from both the rubber/plastic panel and the mainboard.
    Ask FixBot
1 Guide Comment
Where's the replacement speaker link?
Mark Anthony Braganza - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 32
All Time: 636
