Up to 20% off select tools
Anker SoundCore mini disassembly
Views: 22K
View statistics:
Past 24 Hours:
8
Past 7 Days:
79
Past 30 Days:
364
All Time:
22,071
Comments: 26
15 comments on steps, 11 guide comments.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This guide describes how to disassemble and reassemble the Anker SoundCore mini bluetooth box. Once disassembled, single parts can be exchanged / repaired easily.
    1. Anker SoundCore mini disassembly, Casing opening: step 1, image 1 of 3 Anker SoundCore mini disassembly, Casing opening: step 1, image 2 of 3 Anker SoundCore mini disassembly, Casing opening: step 1, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Carefully remove the rubber cover (glued) from the base.
      • Remove the 3 screws using a screwdriver.
      • Pull the lower part carefully to open the casing.
      • You may use a slotted screwdriver, plastic card etc. along the slit to open as the cables are fixed with sealing paste inside.
      • When the slit opened, remove
      • the red battery cable plug and the white speaker cable plug (red arrows) from the socket by pulling and
      • the volume/play control cable by pulling the black lash (green arrow) upward and pulling the cable out of the socket
      • to separate the lower (PCB) part from the speaker & battery part.
      Ask FixBot
    2. Anker SoundCore mini disassembly, Main PCB removal: step 2, image 1 of 1
      • Remove the 4 screws using a screwdriver and take off the PCB from the lower casing.
      • Note: The On/Off switch cover is neither fixed in the casing nor on the PCB. When remounting, pay attention to the correct positioning of the switch cover.
      Ask FixBot
    3. Anker SoundCore mini disassembly, Speaker / battery part opening: step 3, image 1 of 2 Anker SoundCore mini disassembly, Speaker / battery part opening: step 3, image 2 of 2
      • Remove the 4 screws using a screwdriver.
      • Remove the inner separation from the casing by pulling, starting at the opposite side of the volume/play switch cable.
      • Be careful as the volume/play switch cable is still fixed on the other side, so the separation cannot be removed without removing the connector on the other side.
      • You may use a slitted screwdriver, plastic card etc. to push at the lashes (green arrows).
      Ask FixBot
    4. Anker SoundCore mini disassembly, Battery removal: step 4, image 1 of 1
      • Remove the battery pack carefully by pulling it upward (it is fixed by glue only to the speaker casing).
      Ask FixBot
    5. Anker SoundCore mini disassembly, Speaker removal: step 5, image 1 of 2 Anker SoundCore mini disassembly, Speaker removal: step 5, image 2 of 2
      • Remove the volume/play switch cable by pulling the black lash (green arrow) outward, then pulling out the connector from the socket. Remove the inner separation and the volume/play switch cable linked with it.
      • Remove the 2 screws using a screwdriver and remove the speaker.
      Ask FixBot
    6. Anker SoundCore mini disassembly, Volume/play switch removal: step 6, image 1 of 2 Anker SoundCore mini disassembly, Volume/play switch removal: step 6, image 2 of 2
      • Remove the volume/play switch rubber cover (green arrow).
      • Remove the 2 screws using a screwdriver.
      • Pull out the volume/play switch control panel from the inner side of the casing.
      Ask FixBot
When reassembling, pay attention
  • to correctly insert all connectors into their sockets
  • to the right positioning of the speaker and battery cables when pulling them through the inner separation (and reconnecting them to the PCB)
  • to correctly position the On/Off switch cover when remounting the PCB.
To ensure a similar sound quality as before, the cable entries in the inner separation may need sealing after the cables have been reconnected. If this becomes necessary, hot glue or some sealing paste/wax could be used for this.
15 other people completed this guide.
Author
with
Sebastian
1,082 Reputation
3 Guides authored
11 Guide Comments
Much appreciated when some cleaning stuff got spilt through the vents on the top onto the speaker and needed to get it out to clean up the mess. thanks
Mark - Reply Share
Re- the On/Off button - the article talks about getting it in the right position, but the right place seems to be missing. The red goes on the right.
Currently got mine in pieces waiting for it to dry out after it fell in the bath. Fingers crossed as it did seem to work still, just that you also got to hear the Bluetooth module along with your sound!
Ash - Reply Share
What kind of battery does this unit use? Ours won’t hold a charge anymore, and if it takes an easily obtained battery type, I’d gladly open it up and replace it.
JWosnick - Reply Share
1800mah 3.7v 6.7wh li-po battery. Not sure if the li-po batteries are too big when they're that size, as Anker produce their own batteries. I've bought a li-po, so I'll report back with info.
Leanne - Reply Share
I have the same problem. Would love to hear if li-po worked!
Birgitta Berger - Reply Share
Past 24 Hours: 8
Past 7 Days: 79
Past 30 Days: 364
All Time: 22,071
