Anker SoundCore 2 Charging Port Replacement
Views: 5.8K
View statistics:
Past 24 Hours:
7
Past 7 Days:
27
Past 30 Days:
159
All Time:
5,850
Comments: 10
6 comments on steps, 4 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
This is a step by step guide on how to replace the charging port in the Anker SoundCore 2 bluetooth speaker. There are a few reasons on why you may need to replace the charging port, including if your speaker will no longer charge or no longer achieve a full charge. Take a look at the troubleshooting page to see if you need to replace the charging port or not. For this guide, you will need a screwdriver and a soldering tool.
Tools
    1. Anker SoundCore 2 Charging Port Replacement, Front Panel: step 1, image 1 of 2 Anker SoundCore 2 Charging Port Replacement, Front Panel: step 1, image 2 of 2
      • Insert a spudger between the front panel and the body of the speaker.
      • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
      Ask FixBot
    1. Anker SoundCore 2 Charging Port Replacement, Motherboard: step 2, image 1 of 3 Anker SoundCore 2 Charging Port Replacement, Motherboard: step 2, image 2 of 3 Anker SoundCore 2 Charging Port Replacement, Motherboard: step 2, image 3 of 3
      • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
      • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
      • Use your hand to remove the speakers.
      Ask FixBot
    2. Anker SoundCore 2 Charging Port Replacement: step 3, image 1 of 3 Anker SoundCore 2 Charging Port Replacement: step 3, image 2 of 3 Anker SoundCore 2 Charging Port Replacement: step 3, image 3 of 3
      • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
      • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
      Ask FixBot
    1. Anker SoundCore 2 Charging Port Replacement, Charging Port: step 4, image 1 of 2 Anker SoundCore 2 Charging Port Replacement, Charging Port: step 4, image 2 of 2
      • Desolder the charging port from the motherboard and solder a new one on.
      • For help with soldering and desoldering, follow this guide.
      Ask FixBot
5 other people completed this guide.
4 Guide Comments
Hello please what's the model of the ESD4 and C34 close to the charging port?
Abel Omeokwe - Reply Share
Where can i get a replacement charging Port?
A K - Reply Share
what's the micro usb port part number? I want to replace it but can't find info on it anywhere.
Tomasz Konwalski - Reply Share
I've made the replacement, but with a spare type c port and...it's not working. Can someone help?
Delyan - Reply Share
Past 24 Hours: 7
Past 7 Days: 27
Past 30 Days: 159
All Time: 5,850
