Anker SoundCore 2 Bluetooth Chip Replacement
    1. Anker SoundCore 2 Bluetooth Chip Replacement, Front Panel: step 1, image 1 of 2 Anker SoundCore 2 Bluetooth Chip Replacement, Front Panel: step 1, image 2 of 2
      • Insert a spudger between the front panel and the body of the speaker.
      • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
      Ask FixBot
    1. Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: step 2, image 1 of 3 Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: step 2, image 2 of 3 Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: step 2, image 3 of 3
      • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
      • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
      • Use your hand to remove the speakers.
      Ask FixBot
    2. Anker SoundCore 2 Bluetooth Chip Replacement: step 3, image 1 of 3 Anker SoundCore 2 Bluetooth Chip Replacement: step 3, image 2 of 3 Anker SoundCore 2 Bluetooth Chip Replacement: step 3, image 3 of 3
      • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
      • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
      Ask FixBot
    1. Anker SoundCore 2 Bluetooth Chip Replacement, Bluetooth Chip: step 4, image 1 of 2 Anker SoundCore 2 Bluetooth Chip Replacement, Bluetooth Chip: step 4, image 2 of 2
      • Desolder the bluetooth chip and solder a new one on the motherboard where the existing one was.
      • For help desoldering and soldering, follow this guide.
      Ask FixBot
1 Guide Comment
My soundcore 2 will randomly peak in volume. It gets louder and then goes back to normal in random short bursts.
foxknight19 - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 60
All Time: 3,039
