Angelcare AC401 Baby Monitor Disassembly
    1. Angelcare AC401 Baby Monitor Disassembly, Angelcare AC401 Baby Monitor Disassembly: step 1, image 1 of 2 Angelcare AC401 Baby Monitor Disassembly, Angelcare AC401 Baby Monitor Disassembly: step 1, image 2 of 2
      • first remove the 2 screws at the green plastic plate.
      Ask FixBot
    2. Angelcare AC401 Baby Monitor Disassembly: step 2, image 1 of 1
      • remove the plastic plate ( battery compartment)
      • you'll see that there are 2 more screws. Remove them.
      Ask FixBot
    3. Angelcare AC401 Baby Monitor Disassembly: step 3, image 1 of 2 Angelcare AC401 Baby Monitor Disassembly: step 3, image 2 of 2
      • now gently remove the green plastic plate arrounf the baby monitor ( arround the screen) use a spudger to click it open.
      Ask FixBot
    4. Angelcare AC401 Baby Monitor Disassembly: step 4, image 1 of 2 Angelcare AC401 Baby Monitor Disassembly: step 4, image 2 of 2
      • now open the monitor by clicking it open or slide it open. Sometimes its easier to use a spudger.
      • be carefull for the electric wires.
      Ask FixBot
    5. Angelcare AC401 Baby Monitor Disassembly: step 5, image 1 of 2 Angelcare AC401 Baby Monitor Disassembly: step 5, image 2 of 2
      • 2 battery's were exploded so the acid was on the black electric power wire.
      • use a cotton swab with a little bit of destilled water.
      Ask FixBot
    6. Angelcare AC401 Baby Monitor Disassembly: step 6, image 1 of 1
      • remove the 2 PCB's by removing the screws shown in the picture.
      Ask FixBot
    7. Angelcare AC401 Baby Monitor Disassembly: step 7, image 1 of 1
      • pull the first PCB up and remove the screws of the second PCB.
      • after removing the two PCB's, clean the acid on the PCB.
      • after cleaning the PCB's put it al together again.
      Ask FixBot
      • first remove the battery lid. 1 screw.
      • slide it out like you see in picture
      • remove battery's
      Ask FixBot
6 other people completed this guide.
Kevin D
7,550 Reputation
21 Guides authored
13 Guide Comments
Thanks for this. I couldn't figure out how to get the blue clip off without breaking it to clean some dirt on the screen. Googled it, found this, job done.
Pete H - Reply Share
Sometimes the activity of the reference quartz is 11,150 MHz, and the devices do not find each other.
I have so repaired the parent module.
Dmitriy, the city of Volzhsky.
Dmitriy N - Reply Share
Hi Dimitriy - I am experiencing the issue with not finding devices each other. How have you fix it ? Is it a matter of replacing the reference quartz with new one ?
Jan - Reply Share
Hi. At my Angelcare (AC401) parent unit the screen has slowly become worse and worse. At first, parts of the temperature figures dissapeared, then the symbols around and now I no longer see anything... But the unit still works! (And alert me if the baby's crying) What do you think, is there anything I can do or do I need to buy a new one?
Terese Rehn - Reply Share
Hi There. I’m having the same problem. Did you find a fix or did you buy a new unit?
Eugene - Reply Share
Past 24 Hours: 6
Past 7 Days: 13
Past 30 Days: 73
All Time: 15,965
