Aneng AN8008 Fuse Replacement
    1. Aneng AN8008 Fuse Replacement, Place the multimeter on its front: step 1, image 1 of 2 Aneng AN8008 Fuse Replacement, Place the multimeter on its front: step 1, image 2 of 2
      • Place the multimeter on its front.
      • Flip up the kickstand.
      Ask FixBot
    2. Aneng AN8008 Fuse Replacement, Unscrew the battery cover: step 2, image 1 of 1
      Tool used on this step:
      Phillips #1 Screwdriver
      $5.49
      Buy
      • Use a PH1 screwdriver to unscrew the single screw holding the battery cover and kickstand.
      Ask FixBot
    3. Aneng AN8008 Fuse Replacement, Remove the battery cover: step 3, image 1 of 2 Aneng AN8008 Fuse Replacement, Remove the battery cover: step 3, image 2 of 2
      • Remove the battery cover and kickstand.
      • Remove the batteries, if present.
      Ask FixBot
    4. Aneng AN8008 Fuse Replacement, Unscrew the back cover: step 4, image 1 of 1
      $5.49
      Buy
      Ask FixBot
    5. Aneng AN8008 Fuse Replacement, Separate the back cover: step 5, image 1 of 1
      iFixit Opening Picks (Set of 6)
      $4.95
      Buy
      • Insert a pick into the top gap between the backshell and front cover.
      • Partly leverage the front cover away from the backshell.
      Ask FixBot
    6. Aneng AN8008 Fuse Replacement, Remove the back cover: step 6, image 1 of 2 Aneng AN8008 Fuse Replacement, Remove the back cover: step 6, image 2 of 2
      $4.95
      Buy
      • Insert a pick into the bottom gap between the backshell and front cover.
      • Fully leverage the front cover out of the backshell.
      Ask FixBot
    1. Aneng AN8008 Fuse Replacement, Remove the blown fuse: step 7, image 1 of 1
      • Locate the two fuses:
      • A 10A fuse for amperage measurements.
      • A 200mA fuse for voltage measurements
      • Remove the blown fuse.
      • Clean any soot from the contacts using cotton swabs and rubbing alcohol to ensure a good connection before installing a new fuse.
      • Install a the new fuse.
      Ask FixBot
Sebastian
33,565 Reputation
72 Guides authored
German Translators Member of German Translators
Community
51 Members
6,481 Guides authored
1 Guide Comment
any source for the .2a fuse? I found a suitable 10a fuse on amazon.
Vincent Mitchell - Reply Share
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 45
All Time: 819
