Andoer HDV 107 Battery Replacement
  1. Andoer HDV 107 Battery Replacement, Battery: step 1, image 1 of 1
    • At the bottom of the camera you will see the battery compartment cover as seen in the picture.
    • To open this compartment, apply pressure in the direction of the arrow and remove.
    Ask FixBot
  2. Andoer HDV 107 Battery Replacement: step 2, image 1 of 1
    • You will see the battery being held in place by a clear plastic kickstand.
    • Use your finger to move the kickstand away from the battery.
    Ask FixBot
  3. Andoer HDV 107 Battery Replacement: step 3, image 1 of 1
    • With your other hand press down on the battery slightly and remove the battery.
    • If the battery does not come out right away try to line the battery up with the sides to give it a clear path out of the compartment.
    Ask FixBot
Isaac Saron
528 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 27
All Time: 757
