Andobil Easy Clip Car Mount Replacement
  1. Andobil Easy Clip Car Mount Replacement, Car Mounting Clip: step 1, image 1 of 1
    • In this case, the plastic connecting to the metal spring failed and caused one of the clip arms to break off.
    • Be sure to remove any pieces of broken plastic before you begin the fix.
    Ask FixBot
  2. Andobil Easy Clip Car Mount Replacement: step 2, image 1 of 1
    • Loosen the knob on the back of the phone holder.
    • Be sure to hold on to this knob as it will be integral to the rest of the fix.
    Ask FixBot
  3. Andobil Easy Clip Car Mount Replacement: step 3, image 1 of 2 Andobil Easy Clip Car Mount Replacement: step 3, image 2 of 2
    • Once the knob is fully removed, the inside ball joint loosens up and can be moved around.
    • Remove the ball joint from the base of the phone holder.
    Ask FixBot
  4. Andobil Easy Clip Car Mount Replacement: step 4, image 1 of 1
    • Remove the tightening knob and set the broken clip aside or toss it in the trash.
    Ask FixBot
  5. Andobil Easy Clip Car Mount Replacement: step 5, image 1 of 2 Andobil Easy Clip Car Mount Replacement: step 5, image 2 of 2
    • Locate the replacement clip that comes with the Andobil Easy Clip Car Mount Kit.
    • Put Tightening Knob on top of the new ball-jointed clip.
    Ask FixBot
  6. Andobil Easy Clip Car Mount Replacement: step 6, image 1 of 1
    • Insert the new clipping mechanism into the back of the phone holder.
    Ask FixBot
  7. Andobil Easy Clip Car Mount Replacement: step 7, image 1 of 1
    • Open the Jaws using the knob on the top of the ball joint mechanism.
    Ask FixBot
  8. Andobil Easy Clip Car Mount Replacement: step 8, image 1 of 1
    • Line up the jaws with the car vent and then use the knob on the bottom to close the jaws.
    Ask FixBot
  9. Andobil Easy Clip Car Mount Replacement: step 9, image 1 of 1
    • Tighten the knob on the back of the phone holder once you have adjusted it to the correct angle.
    Ask FixBot
  10. Andobil Easy Clip Car Mount Replacement: step 10, image 1 of 1
    • Once you've finished tightening the knob, you are finished! This is the finished Product!
    Ask FixBot
Alexander Tavares
205 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 102
All Time: 3,511
