Anbernic RG35XXSP Action Buttons Replacement
  1. Anbernic RG35XXSP Action Buttons Replacement, Battery: step 1, image 1 of 3 Anbernic RG35XXSP Action Buttons Replacement, Battery: step 1, image 2 of 3 Anbernic RG35XXSP Action Buttons Replacement, Battery: step 1, image 3 of 3
    • Power the device off before starting the disassembly process.
    • Close the device and turn it over so the bottom faces upward.
    Ask FixBot
  2. Anbernic RG35XXSP Action Buttons Replacement: step 2, image 1 of 2 Anbernic RG35XXSP Action Buttons Replacement: step 2, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the single 5 mm screw securing the battery cover.
    • Lift the battery door and remove it.
    Ask FixBot
  3. Anbernic RG35XXSP Action Buttons Replacement: step 3, image 1 of 2 Anbernic RG35XXSP Action Buttons Replacement: step 3, image 2 of 2
    • Use a T6 Torx screwdriver to remove the four 5 mm screws.
    • Lift the whole back case with the battery from the device.
    • Don't pull it away because the battery is connected to the board.
    Ask FixBot
  4. Anbernic RG35XXSP Action Buttons Replacement: step 4, image 1 of 3 Anbernic RG35XXSP Action Buttons Replacement: step 4, image 2 of 3 Anbernic RG35XXSP Action Buttons Replacement: step 4, image 3 of 3
    • Remove the battery from the back compartment and fit it through the gap in the back case.
    • Put the plastic case aside for reassembly.
    Ask FixBot
  5. Anbernic RG35XXSP Action Buttons Replacement: step 5, image 1 of 3 Anbernic RG35XXSP Action Buttons Replacement: step 5, image 2 of 3 Anbernic RG35XXSP Action Buttons Replacement: step 5, image 3 of 3
    • Pinch the sides of the battery connector and slide it from the socket to disconnect the battery cable.
    • Remove the battery.
    Ask FixBot
  6. Anbernic RG35XXSP Action Buttons Replacement, Action buttons: step 6, image 1 of 2 Anbernic RG35XXSP Action Buttons Replacement, Action buttons: step 6, image 2 of 2
    • Pinch the R2 button and gently lift it to remove it.
    • Pinch the R1 button and gently lift it to remove it.
    • You will have to pull a little harder as it has a plastic pin that is connected to the body.
    Ask FixBot
  7. Anbernic RG35XXSP Action Buttons Replacement: step 7, image 1 of 2 Anbernic RG35XXSP Action Buttons Replacement: step 7, image 2 of 2
    • Pinch the L2 button and gently lift it to remove it.
    • Pinch the L1 button and gently lift it to remove it.
    Ask FixBot
  8. Anbernic RG35XXSP Action Buttons Replacement: step 8, image 1 of 2 Anbernic RG35XXSP Action Buttons Replacement: step 8, image 2 of 2
    • Use tweezers to pull the power & reset buttons up from the side of the device
    Ask FixBot
  9. Anbernic RG35XXSP Action Buttons Replacement: step 9, image 1 of 2 Anbernic RG35XXSP Action Buttons Replacement: step 9, image 2 of 2
    • Use tweezers to remove the volume buttons from the side of the case.
    • The plus side of the buttons should be closer to the back of the device.
    Ask FixBot
  10. Anbernic RG35XXSP Action Buttons Replacement: step 10, image 1 of 3 Anbernic RG35XXSP Action Buttons Replacement: step 10, image 2 of 3 Anbernic RG35XXSP Action Buttons Replacement: step 10, image 3 of 3
    • Remove the green paper sheet from the motherboard.
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws from the motherboard.
    Ask FixBot
  11. Anbernic RG35XXSP Action Buttons Replacement: step 11, image 1 of 3 Anbernic RG35XXSP Action Buttons Replacement: step 11, image 2 of 3 Anbernic RG35XXSP Action Buttons Replacement: step 11, image 3 of 3
    • Flip the motherboard over to reveal the action and directional buttons.
    • Remove the action and directional button gaskets from the motherboard.
    • In some cases, the gaskets may get stuck in the plastic case. If this happens, you can still take out the buttons like normal.
    Ask FixBot
  12. Anbernic RG35XXSP Action Buttons Replacement: step 12, image 1 of 2 Anbernic RG35XXSP Action Buttons Replacement: step 12, image 2 of 2
    • Use tweezers to remove the directional buttons from the case.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 90
All Time: 1,278
