Anbernic RG35XX Shoulder Buttons Replacement
  1. Anbernic RG35XX Shoulder Buttons Replacement, Rear Case: step 1, image 1 of 2 Anbernic RG35XX Shoulder Buttons Replacement, Rear Case: step 1, image 2 of 2
    • Remove the SD card located on the right side of the device by pushing into the SD card slot and pulling the card out.
    • Remove the six 1.2 mm screws that secure the back case with a 1.5 Hex Bit screwdriver.
    Ask FixBot
  2. Anbernic RG35XX Shoulder Buttons Replacement: step 2, image 1 of 1
    • Insert an opening tool into the MicroSD card slot and twist it clockwise to begin releasing the rear case.
    • You'll hear "clicks" as the retaining clips release.
    • Pry around the entire perimeter until the rear case fully releases.
    • Remove the rear case.
    Ask FixBot
  3. Anbernic RG35XX Shoulder Buttons Replacement, Anbernic RG35XX Battery Disconnection: step 3, image 1 of 2 Anbernic RG35XX Shoulder Buttons Replacement, Anbernic RG35XX Battery Disconnection: step 3, image 2 of 2
    • Use your fingernails or tweezers to gently remove the battery connector from its socket.
    Ask FixBot
  4. Anbernic RG35XX Shoulder Buttons Replacement, Shoulder Buttons: step 4, image 1 of 2 Anbernic RG35XX Shoulder Buttons Replacement, Shoulder Buttons: step 4, image 2 of 2
    • Remove the two 1 mm Phillips screws that secure each of the two the shoulder button brackets.
    • Remove the plates with your index finger and thumb or with tweezers.
    Ask FixBot
  5. Anbernic RG35XX Shoulder Buttons Replacement: step 5, image 1 of 2 Anbernic RG35XX Shoulder Buttons Replacement: step 5, image 2 of 2
    • Remove the four shoulder buttons with your index finger and thumb or tweezers by pushing the hooks upwards then down the clasps.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 58
All Time: 719
