Anbernic RG35XX Screen Replacement
Views: 5.8K
View statistics:
Past 24 Hours:
15
Past 7 Days:
75
Past 30 Days:
328
All Time:
5,810
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The screen in the Anbernic RG35xx is responsible for displaying games/software. If your screen isn't functioning properly, this guide demonstrates how to replace your screen.
Tools
    1. Anbernic RG35XX Screen Replacement, Rear Case: step 1, image 1 of 2 Anbernic RG35XX Screen Replacement, Rear Case: step 1, image 2 of 2
      • Remove the SD card located on the right side of the device by pushing into the SD card slot and pulling the card out.
      • Remove the six 1.2 mm screws that secure the back case with a 1.5 Hex Bit screwdriver.
      Ask FixBot
    2. Anbernic RG35XX Screen Replacement: step 2, image 1 of 1
      • Insert an opening tool into the MicroSD card slot and twist it clockwise to begin releasing the rear case.
      • You'll hear "clicks" as the retaining clips release.
      • Pry around the entire perimeter until the rear case fully releases.
      • Remove the rear case.
      Ask FixBot
    1. Anbernic RG35XX Screen Replacement, Anbernic RG35XX Battery Disconnection: step 3, image 1 of 2 Anbernic RG35XX Screen Replacement, Anbernic RG35XX Battery Disconnection: step 3, image 2 of 2
      • Use your fingernails or tweezers to gently remove the battery connector from its socket.
      Ask FixBot
    1. Anbernic RG35XX Screen Replacement, Motherboard: step 4, image 1 of 1
      • Disconnect the red audio cable from its motherboard port by carefully pulling the connector with your index finger and thumb or with fine tip tweezers.
      Ask FixBot
    2. Anbernic RG35XX Screen Replacement: step 5, image 1 of 1
      • Remove the six 1 mm Phillips screws that secure the motherboard to the case.
      Ask FixBot
    3. Anbernic RG35XX Screen Replacement: step 6, image 1 of 3 Anbernic RG35XX Screen Replacement: step 6, image 2 of 3 Anbernic RG35XX Screen Replacement: step 6, image 3 of 3
      • Flip up the black ZIF locking flap that secures the bronze ribbon cable.
      • Gently disconnect the bronze ribbon cable.
      • Lift the motherboard up and out the chassis.
      Ask FixBot
    1. Anbernic RG35XX Screen Replacement, Screen: step 7, image 1 of 1
      • The wire is not part of the sticker.
      • Remove the black sticker on the back of the screen.
      Ask FixBot
    2. Anbernic RG35XX Screen Replacement: step 8, image 1 of 3 Anbernic RG35XX Screen Replacement: step 8, image 2 of 3 Anbernic RG35XX Screen Replacement: step 8, image 3 of 3
      • The screen is attached with adhesive.
      • Do not heat the device too much, stop at regular intervals and insure that no pieces are being affected badly.
      • Use a hair dryer to gently heat the rear of the screen until it's almost too hot to touch.
      • Insert a jimmy between the screen and plastic bracket. Once a slim gap is opened, insert an opening pick between the plastic bracket and rear screen.
      • Reheat the screen as needed.
      • Continue to insert opening picks around the entire perimeter of the screen as you pry to avoid the adhesive from reengaging.
      • Once the screen fully releases, remove it.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 15
Past 7 Days: 75
Past 30 Days: 328
All Time: 5,810
