Anbernic RG35XX Motherboard Replacement
  1. Anbernic RG35XX Motherboard Replacement, Rear Case: step 1, image 1 of 2 Anbernic RG35XX Motherboard Replacement, Rear Case: step 1, image 2 of 2
    • Remove the SD card located on the right side of the device by pushing into the SD card slot and pulling the card out.
    • Remove the six 1.2 mm screws that secure the back case with a 1.5 Hex Bit screwdriver.
    Ask FixBot
  2. Anbernic RG35XX Motherboard Replacement: step 2, image 1 of 1
    • Insert an opening tool into the MicroSD card slot and twist it clockwise to begin releasing the rear case.
    • You'll hear "clicks" as the retaining clips release.
    • Pry around the entire perimeter until the rear case fully releases.
    • Remove the rear case.
    Ask FixBot
  3. Anbernic RG35XX Motherboard Replacement, Anbernic RG35XX Battery Disconnection: step 3, image 1 of 2 Anbernic RG35XX Motherboard Replacement, Anbernic RG35XX Battery Disconnection: step 3, image 2 of 2
    • Use your fingernails or tweezers to gently remove the battery connector from its socket.
    Ask FixBot
  4. Anbernic RG35XX Motherboard Replacement, Motherboard: step 4, image 1 of 1
    • Disconnect the red audio cable from its motherboard port by carefully pulling the connector with your index finger and thumb or with fine tip tweezers.
    Ask FixBot
  5. Anbernic RG35XX Motherboard Replacement: step 5, image 1 of 1
    • Remove the six 1 mm Phillips screws that secure the motherboard to the case.
    Ask FixBot
  6. Anbernic RG35XX Motherboard Replacement: step 6, image 1 of 3 Anbernic RG35XX Motherboard Replacement: step 6, image 2 of 3 Anbernic RG35XX Motherboard Replacement: step 6, image 3 of 3
    • Flip up the black ZIF locking flap that secures the bronze ribbon cable.
    • Gently disconnect the bronze ribbon cable.
    • Lift the motherboard up and out the chassis.
    Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 23
Past 30 Days: 115
All Time: 1,310
