Anbernic RG 40XXV Shoulder Button Replacement
  1. Anbernic RG 40XXV Shoulder Button Replacement, Back Panel Assembly: step 1, image 1 of 3 Anbernic RG 40XXV Shoulder Button Replacement, Back Panel Assembly: step 1, image 2 of 3 Anbernic RG 40XXV Shoulder Button Replacement, Back Panel Assembly: step 1, image 3 of 3
    • Remove the micro SD card located on the left and right sides of the device by pushing into the SD card slot and pulling the card out.
    • Unscrew all six 7.5 mm screws on the backside of the case using a 1.5 mm hex screwdriver.
    Ask FixBot
  2. Anbernic RG 40XXV Shoulder Button Replacement: step 2, image 1 of 2 Anbernic RG 40XXV Shoulder Button Replacement: step 2, image 2 of 2
    • Take apart the case by separating the front and back sides using an iFixit opening tool.
    • When using the opening tool, carefully pry open the case to avoid damaging the device.
    Ask FixBot
  3. Anbernic RG 40XXV Shoulder Button Replacement: step 3, image 1 of 2 Anbernic RG 40XXV Shoulder Button Replacement: step 3, image 2 of 2
    • Disconnect the battery connection cable by gently pulling it away with angled tweezers from the slot that connects the cable to the motherboard.
    • The cable connection to the motherboard is labeled "+BAT-" for easy identification.
    Ask FixBot
  4. Anbernic RG 40XXV Shoulder Button Replacement, Shoulder Button: step 4, image 1 of 3 Anbernic RG 40XXV Shoulder Button Replacement, Shoulder Button: step 4, image 2 of 3 Anbernic RG 40XXV Shoulder Button Replacement, Shoulder Button: step 4, image 3 of 3
    • Using a Phillips #000 screwdriver, unscrew the six 5 mm screws holding the shoulder buttons in place.
    Ask FixBot
  5. Anbernic RG 40XXV Shoulder Button Replacement: step 5, image 1 of 2 Anbernic RG 40XXV Shoulder Button Replacement: step 5, image 2 of 2
    • Use a pair of ESD-safe tweezers to remove the covers holding the shoulder buttons in place.
    • Place the shoulder button covers to the side to allow easy accessibility to the shoulder buttons for replacement.
    Ask FixBot
  6. Anbernic RG 40XXV Shoulder Button Replacement: step 6, image 1 of 2 Anbernic RG 40XXV Shoulder Button Replacement: step 6, image 2 of 2
    • After removing the covers from the shoulder buttons, pull the buttons out. They will easily dislodge from the back of the case.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 50
All Time: 500
