Analogue Pocket Power and Volume Buttons Board Replacement
  1. Analogue Pocket Power and Volume Buttons Board Replacement, Prepare your device for disassembly: step 1, image 1 of 3 Analogue Pocket Power and Volume Buttons Board Replacement, Prepare your device for disassembly: step 1, image 2 of 3 Analogue Pocket Power and Volume Buttons Board Replacement, Prepare your device for disassembly: step 1, image 3 of 3
    • Unplug all cables and fully power off your device.
    • Working on your device requires laying it screen-side down. To prevent damage, lay it on a soft surface such as a towel.
    Ask FixBot
  2. Analogue Pocket Power and Volume Buttons Board Replacement, Unfasten the battery shell: step 2, image 1 of 2 Analogue Pocket Power and Volume Buttons Board Replacement, Unfasten the battery shell: step 2, image 2 of 2
    • Use a T6 Torx screwdriver to remove the four 13.4 mm‑long screws securing the battery shell.
    Ask FixBot
  3. Analogue Pocket Power and Volume Buttons Board Replacement, Remove the battery shell: step 3, image 1 of 3 Analogue Pocket Power and Volume Buttons Board Replacement, Remove the battery shell: step 3, image 2 of 3 Analogue Pocket Power and Volume Buttons Board Replacement, Remove the battery shell: step 3, image 3 of 3
    Ask FixBot
  4. Analogue Pocket Power and Volume Buttons Board Replacement, Disconnect the battery: step 4, image 1 of 2 Analogue Pocket Power and Volume Buttons Board Replacement, Disconnect the battery: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use blunt nose tweezers to pull the battery connector out of its socket on the bottom right corner of your device.
    • If you're having trouble, try rocking the connector side-to-side to help loosen it.
    • During reassembly, use the flat end of a spudger to push down on the edges of the connector until it's secure in the socket.
    Ask FixBot
  5. Analogue Pocket Power and Volume Buttons Board Replacement, Remove the battery: step 5, image 1 of 3 Analogue Pocket Power and Volume Buttons Board Replacement, Remove the battery: step 5, image 2 of 3 Analogue Pocket Power and Volume Buttons Board Replacement, Remove the battery: step 5, image 3 of 3
    • Lift one of the battery's short edges until the clips release.
    • Remove the battery.
    • During reassembly, push the battery into its recess until the clips engage.
    Ask FixBot
  6. Analogue Pocket Power and Volume Buttons Board Replacement, Unclip the button board: step 6, image 1 of 3 Analogue Pocket Power and Volume Buttons Board Replacement, Unclip the button board: step 6, image 2 of 3 Analogue Pocket Power and Volume Buttons Board Replacement, Unclip the button board: step 6, image 3 of 3
    • A plastic clip secures the center of the button board.
    • Use the point of a spudger to push the clip out and release the board.
    • Don't try to remove the board—a delicate ribbon cable secures it to the device.
    Ask FixBot
  7. Analogue Pocket Power and Volume Buttons Board Replacement, Reposition the button board: step 7, image 1 of 3 Analogue Pocket Power and Volume Buttons Board Replacement, Reposition the button board: step 7, image 2 of 3 Analogue Pocket Power and Volume Buttons Board Replacement, Reposition the button board: step 7, image 3 of 3
    • Swing the bottom edge of the button board up and over the cartridge reader.
    • Set the board on top of the cartridge reader so the cable's connector is facing the bottom of the device.
    • During reassembly:
    • Put the top edges of the board under their tabs on the rear shell.
    • Lay the board onto the rear shell so the alignment posts go into their circular cutouts on the board.
    • Press the board down until the plastic clip engages.
    Ask FixBot
  8. Analogue Pocket Power and Volume Buttons Board Replacement, Disconnect the button board: step 8, image 1 of 3 Analogue Pocket Power and Volume Buttons Board Replacement, Disconnect the button board: step 8, image 2 of 3 Analogue Pocket Power and Volume Buttons Board Replacement, Disconnect the button board: step 8, image 3 of 3
    • Use the tip of a spudger or a clean fingernail to flip up the hinged locking flap on the board cable ZIF connector located on the board itself.
    • Use blunt nose tweezers to pull the cable straight out of its socket.
    Ask FixBot
  9. Analogue Pocket Power and Volume Buttons Board Replacement, Remove the board: step 9, image 1 of 2 Analogue Pocket Power and Volume Buttons Board Replacement, Remove the board: step 9, image 2 of 2
    • Remove the board.
    Ask FixBot
  10. Analogue Pocket Power and Volume Buttons Board Replacement, Unclip the rear shell: step 10, image 1 of 3 Analogue Pocket Power and Volume Buttons Board Replacement, Unclip the rear shell: step 10, image 2 of 3 Analogue Pocket Power and Volume Buttons Board Replacement, Unclip the rear shell: step 10, image 3 of 3
    • Sliding tabs secure the perimeter of the rear shell.
    • Firmly grip your device with one hand.
    • With your free hand, lift the bottom edge of the rear shell until it clears the front shell.
    • Pull the rear shell down until the sliding tabs disengage.
    Ask FixBot
  11. Analogue Pocket Power and Volume Buttons Board Replacement, Remove the rear shell: step 11, image 1 of 3 Analogue Pocket Power and Volume Buttons Board Replacement, Remove the rear shell: step 11, image 2 of 3 Analogue Pocket Power and Volume Buttons Board Replacement, Remove the rear shell: step 11, image 3 of 3
    • Remove the rear shell.
    • Thread the button board cable through its slot in the rear shell.
    • Lay the rear shell on the front shell so its bottom edge slightly overhangs.
    • This allows the tabs to slide into place. If the rear shell is perfectly flush with the front shell, the tabs won't slide.
    • Push the rear shell in and slide it up to engage the sliding tabs.
    Ask FixBot
  12. Analogue Pocket Power and Volume Buttons Board Replacement, Disconnect the board: step 12, image 1 of 3 Analogue Pocket Power and Volume Buttons Board Replacement, Disconnect the board: step 12, image 2 of 3 Analogue Pocket Power and Volume Buttons Board Replacement, Disconnect the board: step 12, image 3 of 3
    Buy
    • Use the tip of a spudger or a clean fingernail to flip up the hinged locking flap on the power and volume button cable ZIF connector.
    Ask FixBot
  13. Analogue Pocket Power and Volume Buttons Board Replacement, Remove the board: step 13, image 1 of 3 Analogue Pocket Power and Volume Buttons Board Replacement, Remove the board: step 13, image 2 of 3 Analogue Pocket Power and Volume Buttons Board Replacement, Remove the board: step 13, image 3 of 3
    Tesa 61395 Tape
    $8.95
    Buy
    • Adhesive secures power and volume button board to the front shell.
    • Insert the point of a spudger between the motherboard and the left side of the button board.
    • Use the point of a spudger to push the button board out to separate the adhesive securing it.
    • Grip the board itself with blunt nose tweezers and remove it.
    • If you're reusing your board, the leftover adhesive should be sticky enough to adequately secure it.
    • If your new board comes with pre-installed adhesive, remove any linings and use a spudger to press the board into place.
    • If your board doesn't have adhesive or the leftover adhesive isn't sticky enough, use strips of thin double-sided tape such as Tesa Tape to secure it.
    Ask FixBot
Spencer Day
196,379 Reputation
1,243 Guides authored
iFixit Member of iFixit
Staff
123 Members
28,236 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 33
All Time: 478
