Analogue Pocket Left Speaker Replacement
  1. Analogue Pocket Left Speaker Replacement, Prepare your device for disassembly: step 1, image 1 of 3 Analogue Pocket Left Speaker Replacement, Prepare your device for disassembly: step 1, image 2 of 3 Analogue Pocket Left Speaker Replacement, Prepare your device for disassembly: step 1, image 3 of 3
    • Unplug all cables and fully power off your device.
    • Working on your device requires laying it screen-side down. To prevent damage, lay it on a soft surface such as a towel.
    Ask FixBot
  2. Analogue Pocket Left Speaker Replacement, Unfasten the battery shell: step 2, image 1 of 2 Analogue Pocket Left Speaker Replacement, Unfasten the battery shell: step 2, image 2 of 2
    • Use a T6 Torx screwdriver to remove the four 13.4 mm‑long screws securing the battery shell.
    Ask FixBot
  3. Analogue Pocket Left Speaker Replacement, Remove the battery shell: step 3, image 1 of 3 Analogue Pocket Left Speaker Replacement, Remove the battery shell: step 3, image 2 of 3 Analogue Pocket Left Speaker Replacement, Remove the battery shell: step 3, image 3 of 3
    Ask FixBot
  4. Analogue Pocket Left Speaker Replacement, Disconnect the battery: step 4, image 1 of 2 Analogue Pocket Left Speaker Replacement, Disconnect the battery: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use blunt nose tweezers to pull the battery connector out of its socket on the bottom right corner of your device.
    • If you're having trouble, try rocking the connector side-to-side to help loosen it.
    • During reassembly, use the flat end of a spudger to push down on the edges of the connector until it's secure in the socket.
    Ask FixBot
  5. Analogue Pocket Left Speaker Replacement, Remove the battery: step 5, image 1 of 3 Analogue Pocket Left Speaker Replacement, Remove the battery: step 5, image 2 of 3 Analogue Pocket Left Speaker Replacement, Remove the battery: step 5, image 3 of 3
    • Lift one of the battery's short edges until the clips release.
    • Remove the battery.
    • During reassembly, push the battery into its recess until the clips engage.
    Ask FixBot
  6. Analogue Pocket Left Speaker Replacement, Unclip the button board: step 6, image 1 of 3 Analogue Pocket Left Speaker Replacement, Unclip the button board: step 6, image 2 of 3 Analogue Pocket Left Speaker Replacement, Unclip the button board: step 6, image 3 of 3
    • A plastic clip secures the center of the button board.
    • Use the point of a spudger to push the clip out and release the board.
    • Don't try to remove the board—a delicate ribbon cable secures it to the device.
    Ask FixBot
  7. Analogue Pocket Left Speaker Replacement, Reposition the button board: step 7, image 1 of 3 Analogue Pocket Left Speaker Replacement, Reposition the button board: step 7, image 2 of 3 Analogue Pocket Left Speaker Replacement, Reposition the button board: step 7, image 3 of 3
    • Swing the bottom edge of the button board up and over the cartridge reader.
    • Set the board on top of the cartridge reader so the cable's connector is facing the bottom of the device.
    • During reassembly:
    • Put the top edges of the board under their tabs on the rear shell.
    • Lay the board onto the rear shell so the alignment posts go into their circular cutouts on the board.
    • Press the board down until the plastic clip engages.
    Ask FixBot
  8. Analogue Pocket Left Speaker Replacement, Disconnect the button board: step 8, image 1 of 3 Analogue Pocket Left Speaker Replacement, Disconnect the button board: step 8, image 2 of 3 Analogue Pocket Left Speaker Replacement, Disconnect the button board: step 8, image 3 of 3
    • Use the tip of a spudger or a clean fingernail to flip up the hinged locking flap on the board cable ZIF connector located on the board itself.
    • Use blunt nose tweezers to pull the cable straight out of its socket.
    Ask FixBot
  9. Analogue Pocket Left Speaker Replacement, Remove the board: step 9, image 1 of 2 Analogue Pocket Left Speaker Replacement, Remove the board: step 9, image 2 of 2
    • Remove the board.
    Ask FixBot
  10. Analogue Pocket Left Speaker Replacement, Unclip the rear shell: step 10, image 1 of 3 Analogue Pocket Left Speaker Replacement, Unclip the rear shell: step 10, image 2 of 3 Analogue Pocket Left Speaker Replacement, Unclip the rear shell: step 10, image 3 of 3
    • Sliding tabs secure the perimeter of the rear shell.
    • Firmly grip your device with one hand.
    • With your free hand, lift the bottom edge of the rear shell until it clears the front shell.
    • Pull the rear shell down until the sliding tabs disengage.
    Ask FixBot
  11. Analogue Pocket Left Speaker Replacement, Remove the rear shell: step 11, image 1 of 3 Analogue Pocket Left Speaker Replacement, Remove the rear shell: step 11, image 2 of 3 Analogue Pocket Left Speaker Replacement, Remove the rear shell: step 11, image 3 of 3
    • Remove the rear shell.
    • Thread the button board cable through its slot in the rear shell.
    • Lay the rear shell on the front shell so its bottom edge slightly overhangs.
    • This allows the tabs to slide into place. If the rear shell is perfectly flush with the front shell, the tabs won't slide.
    • Push the rear shell in and slide it up to engage the sliding tabs.
    Ask FixBot
  12. Analogue Pocket Left Speaker Replacement, Disconnect the speaker: step 12, image 1 of 3 Analogue Pocket Left Speaker Replacement, Disconnect the speaker: step 12, image 2 of 3 Analogue Pocket Left Speaker Replacement, Disconnect the speaker: step 12, image 3 of 3
    Buy
    • The left speaker will be on your right-hand side, as the device is laying upside down.
    • Use the tip of a spudger or a clean fingernail to flip up the hinged locking flap on the left speaker cable ZIF connector.
    Ask FixBot
  13. Analogue Pocket Left Speaker Replacement, Unfasten the speaker: step 13, image 1 of 2 Analogue Pocket Left Speaker Replacement, Unfasten the speaker: step 13, image 2 of 2
    • Use a Phillips screwdriver to remove the two 4.7 mm‑long screws securing the left speaker.
    Ask FixBot
  14. Analogue Pocket Left Speaker Replacement, Remove the speaker: step 14, image 1 of 3 Analogue Pocket Left Speaker Replacement, Remove the speaker: step 14, image 2 of 3 Analogue Pocket Left Speaker Replacement, Remove the speaker: step 14, image 3 of 3
    • Insert the point of a spudger between the top left corner of the speaker and the front shell.
    • Pry up the speaker and remove it.
    Ask FixBot
Spencer Day
196,016 Reputation
1,243 Guides authored
iFixit Member of iFixit
Staff
123 Members
27,624 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 38
All Time: 493
