Up to 20% off select tools
Analogue Pocket Button Board Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
78
All Time:
966
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the button board in your Analogue pocket.
This board has the buttons for your bumpers. You might need to replace it if your bumpers aren't working, are inconsistent, or aren't clicking.
Note: Removing the battery from its recess isn't a required step, but it makes accessing the board and its cable easier.
    1. Analogue Pocket Button Board Replacement, Prepare your device for disassembly: step 1, image 1 of 3 Analogue Pocket Button Board Replacement, Prepare your device for disassembly: step 1, image 2 of 3 Analogue Pocket Button Board Replacement, Prepare your device for disassembly: step 1, image 3 of 3
      • Unplug all cables and fully power off your device.
      • Working on your device requires laying it screen-side down. To prevent damage, lay it on a soft surface such as a towel.
      Ask FixBot
    1. Analogue Pocket Button Board Replacement, Unfasten the battery shell: step 2, image 1 of 2 Analogue Pocket Button Board Replacement, Unfasten the battery shell: step 2, image 2 of 2
      • Use a T6 Torx screwdriver to remove the four 13.4 mm‑long screws securing the battery shell.
      Ask FixBot
    2. Analogue Pocket Button Board Replacement, Remove the battery shell: step 3, image 1 of 3 Analogue Pocket Button Board Replacement, Remove the battery shell: step 3, image 2 of 3 Analogue Pocket Button Board Replacement, Remove the battery shell: step 3, image 3 of 3
      Ask FixBot
    1. Analogue Pocket Button Board Replacement, Disconnect the battery: step 4, image 1 of 2 Analogue Pocket Button Board Replacement, Disconnect the battery: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use blunt nose tweezers to pull the battery connector out of its socket on the bottom right corner of your device.
      • If you're having trouble, try rocking the connector side-to-side to help loosen it.
      • During reassembly, use the flat end of a spudger to push down on the edges of the connector until it's secure in the socket.
      Ask FixBot
    2. Analogue Pocket Button Board Replacement, Remove the battery: step 5, image 1 of 3 Analogue Pocket Button Board Replacement, Remove the battery: step 5, image 2 of 3 Analogue Pocket Button Board Replacement, Remove the battery: step 5, image 3 of 3
      • Lift one of the battery's short edges until the clips release.
      • Remove the battery.
      • During reassembly, push the battery into its recess until the clips engage.
      Ask FixBot
    1. Analogue Pocket Button Board Replacement, Unclip the button board: step 6, image 1 of 3 Analogue Pocket Button Board Replacement, Unclip the button board: step 6, image 2 of 3 Analogue Pocket Button Board Replacement, Unclip the button board: step 6, image 3 of 3
      • A plastic clip secures the center of the button board.
      • Use the point of a spudger to push the clip out and release the board.
      • Don't try to remove the board—a delicate ribbon cable secures it to the device.
      Ask FixBot
    2. Analogue Pocket Button Board Replacement, Reposition the button board: step 7, image 1 of 3 Analogue Pocket Button Board Replacement, Reposition the button board: step 7, image 2 of 3 Analogue Pocket Button Board Replacement, Reposition the button board: step 7, image 3 of 3
      • Swing the bottom edge of the button board up and over the cartridge reader.
      • Set the board on top of the cartridge reader so the cable's connector is facing the bottom of the device.
      • During reassembly:
      • Put the top edges of the board under their tabs on the rear shell.
      • Lay the board onto the rear shell so the alignment posts go into their circular cutouts on the board.
      • Press the board down until the plastic clip engages.
      Ask FixBot
    3. Analogue Pocket Button Board Replacement, Disconnect the button board: step 8, image 1 of 3 Analogue Pocket Button Board Replacement, Disconnect the button board: step 8, image 2 of 3 Analogue Pocket Button Board Replacement, Disconnect the button board: step 8, image 3 of 3
      • Use the tip of a spudger or a clean fingernail to flip up the hinged locking flap on the board cable ZIF connector located on the board itself.
      • Use blunt nose tweezers to pull the cable straight out of its socket.
      Ask FixBot
    4. Analogue Pocket Button Board Replacement, Remove the board: step 9, image 1 of 2 Analogue Pocket Button Board Replacement, Remove the board: step 9, image 2 of 2
      • Remove the board.
      Ask FixBot
    1. Analogue Pocket Button Board Replacement, Remove the old cable: step 10, image 1 of 3 Analogue Pocket Button Board Replacement, Remove the old cable: step 10, image 2 of 3 Analogue Pocket Button Board Replacement, Remove the old cable: step 10, image 3 of 3
      • If you suspect your board's cable is damaged, or your new board comes with a cable, follow the next three steps to remove the old one.
      • Sliding tabs secure the perimeter of the rear shell.
      • Firmly grip your device with one hand.
      • With your free hand, lift the bottom edge of the rear shell until it clears the front shell.
      • Pull the rear shell down until the sliding tabs disengage.
      Ask FixBot
    2. Analogue Pocket Button Board Replacement: step 11, image 1 of 3 Analogue Pocket Button Board Replacement: step 11, image 2 of 3 Analogue Pocket Button Board Replacement: step 11, image 3 of 3
      • Remove the rear shell.
      • Thread the button board cable through its slot in the rear shell.
      • Lay the rear shell on the front shell so its bottom edge overhangs slightly.
      • This allows the tabs to slide into place. If the rear shell is perfectly flush with the front shell, the tabs won't slide.
      • Push the rear shell in and slide it up to engage the sliding tabs.
      Ask FixBot
    3. Analogue Pocket Button Board Replacement: step 12, image 1 of 3 Analogue Pocket Button Board Replacement: step 12, image 2 of 3 Analogue Pocket Button Board Replacement: step 12, image 3 of 3
      Buy
      • Use the tip of a spudger or a clean fingernail to flip up the hinged locking flap on the board cable ZIF connector to the bottom left of the cartridge reader.
      Ask FixBot
Author
with
Spencer Day
210,833 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 78
All Time: 966
