Up to 20% off select tools
Analogue Pocket Battery Replacement
Views: 8.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
60
Past 30 Days:
273
All Time:
8,543
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace a dead or worn out battery in your Analogue Pocket.
Note: This guide shows how to replace the battery cell and its housing as one assembly. If you're replacing the battery cell itself, follow this guide to extract it from its housing.
    1. Analogue Pocket Battery Replacement, Prepare your device for disassembly: step 1, image 1 of 3 Analogue Pocket Battery Replacement, Prepare your device for disassembly: step 1, image 2 of 3 Analogue Pocket Battery Replacement, Prepare your device for disassembly: step 1, image 3 of 3
      • Unplug all cables and fully power off your device.
      • Working on your device requires laying it screen-side down. To prevent damage, lay it on a soft surface such as a towel.
      Ask FixBot
    1. Analogue Pocket Battery Replacement, Unfasten the battery shell: step 2, image 1 of 2 Analogue Pocket Battery Replacement, Unfasten the battery shell: step 2, image 2 of 2
      • Use a T6 Torx screwdriver to remove the four 13.4 mm‑long screws securing the battery shell.
      Ask FixBot
    2. Analogue Pocket Battery Replacement, Remove the battery shell: step 3, image 1 of 3 Analogue Pocket Battery Replacement, Remove the battery shell: step 3, image 2 of 3 Analogue Pocket Battery Replacement, Remove the battery shell: step 3, image 3 of 3
      Ask FixBot
    1. Analogue Pocket Battery Replacement, Disconnect the battery: step 4, image 1 of 2 Analogue Pocket Battery Replacement, Disconnect the battery: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use blunt nose tweezers to pull the battery connector out of its socket on the bottom right corner of your device.
      • If you're having trouble, try rocking the connector side-to-side to help loosen it.
      • During reassembly, use the flat end of a spudger to push down on the edges of the connector until it's secure in the socket.
      Ask FixBot
    2. Analogue Pocket Battery Replacement, Remove the battery: step 5, image 1 of 3 Analogue Pocket Battery Replacement, Remove the battery: step 5, image 2 of 3 Analogue Pocket Battery Replacement, Remove the battery: step 5, image 3 of 3
      • Lift one of the battery's short edges until the clips release.
      • Remove the battery.
      • During reassembly, push the battery into its recess until the clips engage.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
Author
with
Spencer Day
210,928 Reputation
1,265 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
2 Guide Comments
So where does one find the replacement battery? Can't find one anywhere?!?
Jonathan Smookler - Reply Share
Great guide, but there are no replacement batteries for sale
Bart Mlotkowski - Reply Share
Past 24 Hours: 2
Past 7 Days: 60
Past 30 Days: 273
All Time: 8,543
