American Plumber Water Filter WC34-PR Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
14
Past 7 Days:
55
Past 30 Days:
174
All Time:
3,303
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace the filter for an American Plumber Water Filter housing model # WC34-PR.
The filter sifts out sediment from the water source entering your house. These particles can harm appliances in your home, and damage water pipes.
Replace the American Plumber Water Filter every 4 months. Replace the filter earlier if there is sediment in the house water or the filter looks dirty.
    1. American Plumber Water Filter WC34-PR Replacement, Filter: step 1, image 1 of 1
      • Locate the water filter in your home.
      • The water filter is typically by where the water comes into the house.
      Ask FixBot
    2. American Plumber Water Filter WC34-PR Replacement: step 2, image 1 of 2 American Plumber Water Filter WC34-PR Replacement: step 2, image 2 of 2
      • Rotate the lever near the water filter up to turn off the water to the house.
      • This may differ depending on your setup.
      Ask FixBot
    3. American Plumber Water Filter WC34-PR Replacement: step 3, image 1 of 2 American Plumber Water Filter WC34-PR Replacement: step 3, image 2 of 2
      • Turn on a faucet inside the house to drain the water out of the pipes.
      • Leave the faucet on until no more water comes out.
      Ask FixBot
    4. American Plumber Water Filter WC34-PR Replacement: step 4, image 1 of 1
      • Place a bucket under the filter.
      Ask FixBot
    5. American Plumber Water Filter WC34-PR Replacement: step 5, image 1 of 2 American Plumber Water Filter WC34-PR Replacement: step 5, image 2 of 2
      • Press the button on top of the device for approximately 10-15 seconds until all of the water is drained.
      Ask FixBot
    6. American Plumber Water Filter WC34-PR Replacement: step 6, image 1 of 3 American Plumber Water Filter WC34-PR Replacement: step 6, image 2 of 3 American Plumber Water Filter WC34-PR Replacement: step 6, image 3 of 3
      • Hold the top of the device and the pipes steady and rotate the clear part of the filter to the left to remove it.
      • Using excessive force may damage your pipes.
      • If the filter housing is stuck, use a strap wrench to loosen the filter.
      • Loop the strap around the filter and place the remaining strap into the slot in the wrench.
      • Ensure the handle of the wrench is close to the filter container and that there is no slack in the strap.
      • Grip the handle firmly to hold the strap in place.
      • Twist to the left to unscrew the filter housing.
      Ask FixBot
    7. American Plumber Water Filter WC34-PR Replacement: step 7, image 1 of 3 American Plumber Water Filter WC34-PR Replacement: step 7, image 2 of 3 American Plumber Water Filter WC34-PR Replacement: step 7, image 3 of 3
      • Remove the filter from the plastic housing.
      • Pour out the remaining water into the bucket.
      Ask FixBot
    8. American Plumber Water Filter WC34-PR Replacement: step 8, image 1 of 2 American Plumber Water Filter WC34-PR Replacement: step 8, image 2 of 2
      • Use a paper towel to wipe sediment out of the filter housing and the gasket.
      Ask FixBot
    9. American Plumber Water Filter WC34-PR Replacement: step 9, image 1 of 1
      • Inspect the gasket to see if it has visible damage or dirt.
      • If the gasket is dirty of damaged, the device may leak when reassembled.
      • Clean any dirt off the rubber ring.
      • If the rubber ring is damaged, replace it with a new gasket.
      Ask FixBot
    10. American Plumber Water Filter WC34-PR Replacement: step 10, image 1 of 1
      • Place a new filter into the housing.
      Ask FixBot
    11. American Plumber Water Filter WC34-PR Replacement: step 11, image 1 of 3 American Plumber Water Filter WC34-PR Replacement: step 11, image 2 of 3 American Plumber Water Filter WC34-PR Replacement: step 11, image 3 of 3
      • Screw the filter housing back on.
      • The filter must be straight and centered in the housing.
      Ask FixBot
    12. American Plumber Water Filter WC34-PR Replacement: step 12, image 1 of 2 American Plumber Water Filter WC34-PR Replacement: step 12, image 2 of 2
      • Turn the water to the house back on.
      • Once unit is filled with water, inspect the filter to ensure there is no leakage.
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 14
Past 7 Days: 55
Past 30 Days: 174
All Time: 3,303
