Ambient Weather WS-2000, 4000, 5000 - Sensor Registration
  1. Ambient Weather WS-2000, 4000, 5000 - Sensor Registration, Ambient Weather WS-2000, 4000, 5000 - Sensor Registration: step 1, image 1 of 2 Ambient Weather WS-2000, 4000, 5000 - Sensor Registration, Ambient Weather WS-2000, 4000, 5000 - Sensor Registration: step 1, image 2 of 2
    • On the home screen of your console, select the settings tab using the bottom right button. It will appear as a gear icon.
    • On the setup screen, you can press the up arrow to highlight the 'More : Setup' option.
    • Using the far left button, the 'plus magnifier', you can select 'More : Setup' to continue to the next screen.
    Ask FixBot
  2. Ambient Weather WS-2000, 4000, 5000 - Sensor Registration: step 2, image 1 of 1
    • Using the up arrow you can highlight the 'Sensor ID : Setup' option.
    • Using the plus magnifier you can select this option, continuing to the next screen.
    Ask FixBot
  3. Ambient Weather WS-2000, 4000, 5000 - Sensor Registration: step 3, image 1 of 2 Ambient Weather WS-2000, 4000, 5000 - Sensor Registration: step 3, image 2 of 2
    • Using the down arrow, you can highlight the ID box next to the sensor you would like to connect.
    • Using the plus magnifier, you can select this option, opening the sensor window.
    Ask FixBot
  4. Ambient Weather WS-2000, 4000, 5000 - Sensor Registration: step 4, image 1 of 3 Ambient Weather WS-2000, 4000, 5000 - Sensor Registration: step 4, image 2 of 3 Ambient Weather WS-2000, 4000, 5000 - Sensor Registration: step 4, image 3 of 3
    • Using the down arrow, highlight the 'Register' option.
    • If you know your devices hexadecimal ID, you can enter it directly into the sensor window instead of using the automatic register function.
    • Using the plus magnifier, you can select this option, causing the console to search for any compatible sensor.
    • If not already blank, the ID box will have a few dashes next to it for a minute or two while it searches for the sensor.
    • If your compatible sensor is on, and within range of your console, it will connect automatically.
    Ask FixBot
This process can be used to make your way to the sensor ID page and register any of the available sensors for the Ambient Weather WS-2000, 4000, or 5000 weather stations.
Tim Elafros
493 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 77
All Time: 280
