Ambient Weather WS-1001-Wifi LCD Screen Replacement
  1. Ambient Weather WS-1001-Wifi LCD Screen Replacement, LCD Screen: step 1, image 1 of 1
    • First, you will need to remove all four M2x1-7 screws (7mm length) located on the back of the device. This should be done using a Phillips #1 screw driver.
    Ask FixBot
  2. Ambient Weather WS-1001-Wifi LCD Screen Replacement: step 2, image 1 of 1
    • From the side of the device use the plastic opening tool to pry the gray front casing from the rear black casing.
    • The ribbon cable is attached inside so the two pieces will not come completely apart. See step 3.
    Ask FixBot
  3. Ambient Weather WS-1001-Wifi LCD Screen Replacement: step 3, image 1 of 1
    • Using a plastic opening tool, carefully press the black bar towards the ribbon and away from the white bar in order to release it.
    • The ribbon cable should come out and be attached to the back of the LCD screen resulting in two separate pieces.
    Ask FixBot
  4. Ambient Weather WS-1001-Wifi LCD Screen Replacement: step 4, image 1 of 2 Ambient Weather WS-1001-Wifi LCD Screen Replacement: step 4, image 2 of 2
    • Next, you need to remove the LCD screen from the front casing.
    • Push on the front of the LCD screen to pop it out as seen in picture 2.
    Ask FixBot
Jeremiah Miskimen
107 Reputation
1 Guide authored
IUPUI, Team S1-G2, Harley Fall 2017 Member of IUPUI, Team S1-G2, Harley Fall 2017
IUPUI-HARLEY-F17S1G2
4 Members
3 Guides authored
2 Guide Comments
Pretty useless guide since this is all pretty self explanatory with no reference on where to get a replacement or even a part number
Jared Dykstra - Reply Share
Exactly right.
j drag - Reply Share
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 22
All Time: 639
