Ambient Weather WS-1001-Wifi Battery Replacement
  1. Ambient Weather WS-1001-Wifi Battery Replacement, Battery: step 1, image 1 of 2 Ambient Weather WS-1001-Wifi Battery Replacement, Battery: step 1, image 2 of 2
    • First, unscrew the 4 M2x1.5-7 screws (7mm length) from the back of the device using a number 1 Phillips screwdriver.
    • Pry the front silver panel away from the back black panel with a plastic opening tool.
    Ask FixBot
  2. Ambient Weather WS-1001-Wifi Battery Replacement: step 2, image 1 of 1
    • Next, the ribbon cable needs to be carefully removed from the back of the LCD screen.
    • Use a plastic opening tool to press the black bar towards the ribbon and away from the white bar gently. This will release the ribbon.
    Ask FixBot
  3. Ambient Weather WS-1001-Wifi Battery Replacement: step 3, image 1 of 2 Ambient Weather WS-1001-Wifi Battery Replacement: step 3, image 2 of 2
    • Remove the 4 M2x1.5-7 screws (7mm length) from the green PCB board.
    • This will result in two pieces, the back black cover and the PCB board.
    Ask FixBot
  4. Ambient Weather WS-1001-Wifi Battery Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • The battery can then be popped out using precision tweezers and replaced with a new one.
    Ask FixBot
Taylor Whitaker
122 Reputation
1 Guide authored
IUPUI, Team S1-G2, Harley Fall 2017 Member of IUPUI, Team S1-G2, Harley Fall 2017
IUPUI-HARLEY-F17S1G2
4 Members
3 Guides authored
1 Guide Comment
Hello. My screen is not working. And the electric cable is good.
C Kaagman - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 28
All Time: 1,131
