AmazonBasics BTV1 Speaker Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
101
All Time:
2,552
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Occasionally speakers start malfunctioning or stop working entirely. In this guide we show you how to replace those speakers and get your AmazonBasics BTV1 running again.
Tools
    1. AmazonBasics BTV1 Speaker Replacement, Speaker: step 1, image 1 of 2 AmazonBasics BTV1 Speaker Replacement, Speaker: step 1, image 2 of 2
      • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
      • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
      Ask FixBot
    2. AmazonBasics BTV1 Speaker Replacement: step 2, image 1 of 2 AmazonBasics BTV1 Speaker Replacement: step 2, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
      • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
      Ask FixBot
    3. AmazonBasics BTV1 Speaker Replacement: step 3, image 1 of 2 AmazonBasics BTV1 Speaker Replacement: step 3, image 2 of 2
      • Tilt the case downwards until the speakers fall out of their housings.
      • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
      Ask FixBot
    4. AmazonBasics BTV1 Speaker Replacement: step 4, image 1 of 2 AmazonBasics BTV1 Speaker Replacement: step 4, image 2 of 2
      • Gently pull the two plastic connectors from the motherboard.
      • Lift the front panel of the case and remove the speakers.
      Ask FixBot
2 other people completed this guide.
Chris Shannon
1,039 Reputation
5 Guides authored
USF Tampa, Team 14-2, Lacy Spring 2016 Member of USF Tampa, Team 14-2, Lacy Spring 2016
USFT-LACY-S16S14G2
3 Members
60 Guides authored
1 Guide Comment
Where do you get replacement speakers? What kind?
laurieshorter - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 101
All Time: 2,552
