AmazonBasics BTV1 Motherboard Replacement
    1. AmazonBasics BTV1 Motherboard Replacement, Motherboard: step 1, image 1 of 2 AmazonBasics BTV1 Motherboard Replacement, Motherboard: step 1, image 2 of 2
      • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
      • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
      Ask FixBot
    2. AmazonBasics BTV1 Motherboard Replacement: step 2, image 1 of 2 AmazonBasics BTV1 Motherboard Replacement: step 2, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
      • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
      Ask FixBot
    3. AmazonBasics BTV1 Motherboard Replacement: step 3, image 1 of 2 AmazonBasics BTV1 Motherboard Replacement: step 3, image 2 of 2
      • Tilt the case downwards until the speakers fall out of their housings.
      • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
      Ask FixBot
    4. AmazonBasics BTV1 Motherboard Replacement: step 4, image 1 of 2 AmazonBasics BTV1 Motherboard Replacement: step 4, image 2 of 2
      • Gently pull each plastic connector from the motherboard.
      • Take a note of which connector goes with each component for easy reassembly.
      • Use a Phillips #1 screwdriver to remove each of the three black 9.6mm screws from the motherboard.
      Ask FixBot
    5. AmazonBasics BTV1 Motherboard Replacement: step 5, image 1 of 1
      • Gently pull out the two ribbon connectors to disconnect the motherboard from the case.
      Ask FixBot
2 other people completed this guide.
Chris Shannon
1,039 Reputation
5 Guides authored
USF Tampa, Team 14-2, Lacy Spring 2016 Member of USF Tampa, Team 14-2, Lacy Spring 2016
USFT-LACY-S16S14G2
3 Members
60 Guides authored
1 Guide Comment
I am looking for I am looking for a Harman Kardon go+play 3 Bluetooth speaker motherboard Can I get it please?
dullah aflah - Reply Share
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 26
All Time: 935
