AmazonBasics BTV1 Micro USB Jack Replacement
    1. AmazonBasics BTV1 Micro USB Jack Replacement, Battery: step 1, image 1 of 2 AmazonBasics BTV1 Micro USB Jack Replacement, Battery: step 1, image 2 of 2
      • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
      • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
      Ask FixBot
    2. AmazonBasics BTV1 Micro USB Jack Replacement: step 2, image 1 of 2 AmazonBasics BTV1 Micro USB Jack Replacement: step 2, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
      • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
      Ask FixBot
    3. AmazonBasics BTV1 Micro USB Jack Replacement: step 3, image 1 of 2 AmazonBasics BTV1 Micro USB Jack Replacement: step 3, image 2 of 2
      • Tilt the case downwards until the speakers fall out of their housings.
      • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
      Ask FixBot
    4. AmazonBasics BTV1 Micro USB Jack Replacement: step 4, image 1 of 2 AmazonBasics BTV1 Micro USB Jack Replacement: step 4, image 2 of 2
      • Gently pull each plastic connector from the motherboard.
      • Take a note of which connector goes with each component for easy reassembly.
      • Use a Phillips #1 screwdriver to remove each of the three black 9.6mm screws from the motherboard.
      Ask FixBot
    5. AmazonBasics BTV1 Micro USB Jack Replacement: step 5, image 1 of 2 AmazonBasics BTV1 Micro USB Jack Replacement: step 5, image 2 of 2
      • Lift the motherboard off the face plate, exposing the battery.
      • Lift the battery out of its housing.
      • Use caution when using tools around the battery; batteries can be dangerous if punctured.
      Ask FixBot
    1. AmazonBasics BTV1 Micro USB Jack Replacement, Micro USB Jack: step 6, image 1 of 3 AmazonBasics BTV1 Micro USB Jack Replacement, Micro USB Jack: step 6, image 2 of 3 AmazonBasics BTV1 Micro USB Jack Replacement, Micro USB Jack: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Using a Phillips #1 screwdriver, remove the two black 10mm screws on the interior of the case on the side with the USB and AUX inputs.
      • Use the plastic opening tool and tweezers at different points to work the audio input casing off.
      Ask FixBot
    2. AmazonBasics BTV1 Micro USB Jack Replacement: step 7, image 1 of 2 AmazonBasics BTV1 Micro USB Jack Replacement: step 7, image 2 of 2
      • Use your fingers to pull casing off by the ribbon.
      • Use a Phillips #1 screwdriver to remove the two 7.6mm screws that hold the board in place.
      Ask FixBot
    3. AmazonBasics BTV1 Micro USB Jack Replacement: step 8, image 1 of 2 AmazonBasics BTV1 Micro USB Jack Replacement: step 8, image 2 of 2
      • Use plastic opening tool to lift up the board.
      • Use plastic opening tool to gently push the aux input jack out of its housing.
      Ask FixBot
    4. AmazonBasics BTV1 Micro USB Jack Replacement: step 9, image 1 of 1
      • Use the soldering iron to heat up solder joint and desoldering wick to remove the solder on each solder pad.
      • Do not apply heat from soldering iron for lengthy periods of time as this could potentially damage the board.
      Ask FixBot
2 other people completed this guide.
Chris Shannon
1,039 Reputation
5 Guides authored
USF Tampa, Team 14-2, Lacy Spring 2016 Member of USF Tampa, Team 14-2, Lacy Spring 2016
USFT-LACY-S16S14G2
3 Members
60 Guides authored
1 Guide Comment
that's awesome didn't i would find a tutorial but here it is. thanks man. What kind of usb connector do i use.
michael sorsby - Reply Share
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 17
All Time: 905
