Up to 20% off select tools
AmazonBasics BTV1 Battery Replacement
Views: 4.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
101
All Time:
4,146
Comments: 9
1 comment on steps, 8 guide comments.
Go to guide comments
Completed: 10
10 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Easy
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Tools
Introduction
Go to step 1 ↓
Sometimes batteries get damaged or lose their ability to hold charge over time. In this guide we will show you how to open up your AmazonBasics BTV1 to replace a defective battery.
    1. AmazonBasics BTV1 Battery Replacement, Battery: step 1, image 1 of 2 AmazonBasics BTV1 Battery Replacement, Battery: step 1, image 2 of 2
      • Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
      • Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
      Ask FixBot
    2. AmazonBasics BTV1 Battery Replacement: step 2, image 1 of 2 AmazonBasics BTV1 Battery Replacement: step 2, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
      • Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
      Ask FixBot
    3. AmazonBasics BTV1 Battery Replacement: step 3, image 1 of 2 AmazonBasics BTV1 Battery Replacement: step 3, image 2 of 2
      • Tilt the case downwards until the speakers fall out of their housings.
      • Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
      Ask FixBot
    4. AmazonBasics BTV1 Battery Replacement: step 4, image 1 of 2 AmazonBasics BTV1 Battery Replacement: step 4, image 2 of 2
      • Gently pull each plastic connector from the motherboard.
      • Take a note of which connector goes with each component for easy reassembly.
      • Use a Phillips #1 screwdriver to remove each of the three black 9.6mm screws from the motherboard.
      Ask FixBot
    5. AmazonBasics BTV1 Battery Replacement: step 5, image 1 of 2 AmazonBasics BTV1 Battery Replacement: step 5, image 2 of 2
      • Lift the motherboard off the face plate, exposing the battery.
      • Lift the battery out of its housing.
      • Use caution when using tools around the battery; batteries can be dangerous if punctured.
      Ask FixBot
10 other people completed this guide.
Author
with
Chris Shannon
1,039 Reputation
5 Guides authored
USF Tampa, Team 14-2, Lacy Spring 2016 Member of USF Tampa, Team 14-2, Lacy Spring 2016
USFT-LACY-S16S14G2
3 Members
60 Guides authored
8 Guide Comments
donde consigo la bateria?
bnet_d72 - Reply Share
Nice job, Chris! Thank you.
David Printz - Reply Share
Hello, anybody know where to get the battery from?
Thank you in advance!
Carlos - Reply Share
Need information on where to get a replacement battery!
dan - Reply Share
Whar kind of battery is it? I need to know so that I can order a new one.
Makayla Kersting - Reply Share
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 101
All Time: 4,146
