AmazonBasics B00Q3KFX8U Motor Replacement
    1. AmazonBasics B00Q3KFX8U Motor Replacement, Drive Gear: step 1, image 1 of 1
      • Remove the shredder assembly from the paper scrap bin.
      Ask FixBot
    2. AmazonBasics B00Q3KFX8U Motor Replacement: step 2, image 1 of 1
      • Remove the two 10mm PH1 screws holding the small black panel in place.
      Ask FixBot
    3. AmazonBasics B00Q3KFX8U Motor Replacement: step 3, image 1 of 2 AmazonBasics B00Q3KFX8U Motor Replacement: step 3, image 2 of 2
      • Remove the six 14mm PH1 screws holding the bottom cover in place.
      • Remove the cover by lifting straight upwards.
      • One of the screws will be hidden beneath a warranty sticker. Simply push the head of the screwdriver through the sticker to access the screw.
      Ask FixBot
    4. AmazonBasics B00Q3KFX8U Motor Replacement: step 4, image 1 of 1
      • Remove the blade/motor assembly from the top cover by lifting straight upwards. Do not disconnect any wiring just yet.
      • The blades are sharp. Coming into contact with them may result in injury.
      Ask FixBot
    5. AmazonBasics B00Q3KFX8U Motor Replacement: step 5, image 1 of 2 AmazonBasics B00Q3KFX8U Motor Replacement: step 5, image 2 of 2
      • Remove the five 8mm PH2 screws from the bracket holding the gears in place.
      Ask FixBot
    6. AmazonBasics B00Q3KFX8U Motor Replacement: step 6, image 1 of 1
      • Use a metal spudger to pry the bracket from the main shredder assembly.
      • If the bracket is attached too tightly for the spudger, carefully use a metal screwdriver to pry it loose.
      Ask FixBot
    7. AmazonBasics B00Q3KFX8U Motor Replacement: step 7, image 1 of 2 AmazonBasics B00Q3KFX8U Motor Replacement: step 7, image 2 of 2
      • Remove the two plastic drive gears from the shredder assembly by lifting straight upwards.
      Ask FixBot
    1. AmazonBasics B00Q3KFX8U Motor Replacement, Motor: step 8, image 1 of 1
      • Remove the four 18mm PH2 screws holding the motor to the main shredder assembly.
      Ask FixBot
    2. AmazonBasics B00Q3KFX8U Motor Replacement: step 9, image 1 of 1
      • Disconnect the motor from the motherboard by either clipping the wires, or using a soldering iron to disconnect the wires directly at the board.
      • To reattach the motor, solder the wires back together, or to the motherboard depending on how you removed them.
      Ask FixBot
William Foley
548 Reputation
4 Guides authored
1 Guide Comment
Do you sell motor?
Binh - Reply Share
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 41
All Time: 1,361
