AmazonBasics B00Q3KFX8U Drive Gear Replacement
  1. AmazonBasics B00Q3KFX8U Drive Gear Replacement, Drive Gear: step 1, image 1 of 1
    • Remove the shredder assembly from the paper scrap bin.
    Ask FixBot
  2. AmazonBasics B00Q3KFX8U Drive Gear Replacement: step 2, image 1 of 1
    • Remove the two 10mm PH1 screws holding the small black panel in place.
    Ask FixBot
  3. AmazonBasics B00Q3KFX8U Drive Gear Replacement: step 3, image 1 of 2 AmazonBasics B00Q3KFX8U Drive Gear Replacement: step 3, image 2 of 2
    • Remove the six 14mm PH1 screws holding the bottom cover in place.
    • Remove the cover by lifting straight upwards.
    • One of the screws will be hidden beneath a warranty sticker. Simply push the head of the screwdriver through the sticker to access the screw.
    Ask FixBot
  4. AmazonBasics B00Q3KFX8U Drive Gear Replacement: step 4, image 1 of 1
    • Remove the blade/motor assembly from the top cover by lifting straight upwards. Do not disconnect any wiring just yet.
    • The blades are sharp. Coming into contact with them may result in injury.
    Ask FixBot
  5. AmazonBasics B00Q3KFX8U Drive Gear Replacement: step 5, image 1 of 2 AmazonBasics B00Q3KFX8U Drive Gear Replacement: step 5, image 2 of 2
    • Remove the five 8mm PH2 screws from the bracket holding the gears in place.
    Ask FixBot
  6. AmazonBasics B00Q3KFX8U Drive Gear Replacement: step 6, image 1 of 1
    • Use a metal spudger to pry the bracket from the main shredder assembly.
    • If the bracket is attached too tightly for the spudger, carefully use a metal screwdriver to pry it loose.
    Ask FixBot
  7. AmazonBasics B00Q3KFX8U Drive Gear Replacement: step 7, image 1 of 2 AmazonBasics B00Q3KFX8U Drive Gear Replacement: step 7, image 2 of 2
    • Remove the two plastic drive gears from the shredder assembly by lifting straight upwards.
    Ask FixBot
William Foley
548 Reputation
4 Guides authored
5 Guide Comments
Where does one buy these gear parts?
opticdreams - Reply Share
Hi, you can buy the gear here: https://www.ebay.com/itm/116169745117
Mr. Master - Reply Share
I need big wheel for Bonsaii C220-A and need a duel gear wheel (1.6 inches and 0.5 inches) Apelila Apelila paper shredder
Raju Nivarthi - Reply Share
Send me a message on eBay, https://www.ebay.com/usr/krunkz, I will recreate your damaged gears for free if you can mail them to me.
Shredder Gears - Reply Share
I would not buy the gears from that link on ebay. I paid 10 dollars for 2 3D printed gears. Both stripped almost immediately. I applied new grease and do not think it was my error, but rather poor quality gear replacements. Not worth the time or money.
acoest - Reply Share
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 53
All Time: 2,260
