AmazonBasics B0050BPWBQ On/Off Switch Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
94
All Time:
3,154
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The On/Off switch located on the front panel may become damaged and no longer function correctly. With a dysfunctional switch, you may not be able to get the shredder to operate.
Tools
    1. AmazonBasics B0050BPWBQ On/Off Switch Replacement, Front and Back Panel Disassembly: step 1, image 1 of 2 AmazonBasics B0050BPWBQ On/Off Switch Replacement, Front and Back Panel Disassembly: step 1, image 2 of 2
      • The unit head needs to be switched to the off position and unplugged before any disassembly.
      • When removing screws in the following steps, make sure the unit is resting on a flat surface because pieces will easily come apart.
      • Remove seven 11 mm Phillips #1 screws from the underside of the head unit.
      Ask FixBot
    2. AmazonBasics B0050BPWBQ On/Off Switch Replacement: step 2, image 1 of 2 AmazonBasics B0050BPWBQ On/Off Switch Replacement: step 2, image 2 of 2
      • Upon removal of the next screws, the front panel and the shredding component attached to it will fall apart from the back panel so have the unit resting on a flat surface.
      • Remove two 50 mm Phillips #1 screws from the middle of the underside of the head unit.
      Ask FixBot
    3. AmazonBasics B0050BPWBQ On/Off Switch Replacement: step 3, image 1 of 1
      • Lay the back panel away from the front panel on a flat surface.
      • The back panel will be light because it is only the plastic, while the front panel will be heavy with the shredding component attached to it.
      Ask FixBot
    4. AmazonBasics B0050BPWBQ On/Off Switch Replacement: step 4, image 1 of 2 AmazonBasics B0050BPWBQ On/Off Switch Replacement: step 4, image 2 of 2
      • Find the green control board that is located next to the shredding motor.
      • Remove two 11 mm Phillips #1 screws located on opposite sides of the control board.
      • You may need to move wires over to find the screws.
      Ask FixBot
    1. AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: step 5, image 1 of 3 AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: step 5, image 2 of 3 AmazonBasics B0050BPWBQ On/Off Switch Replacement, On/Off Switch: step 5, image 3 of 3
      • Pull the front panel away from the shredding unit.
      • Locate the black On/Off switch attached to the front panel where the control board was once attached.
      • Squeeze the wings of the On/Off switch from the inside of the front panel to detach it from its slot in the panel.
      Ask FixBot
Natalie Meert
741 Reputation
4 Guides authored
IUPUI, Team 2-4, Baechle Spring 2016 Member of IUPUI, Team 2-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G4
4 Members
48 Guides authored
1 Guide Comment
Does anyone know where to buy a replacement switch?
Shawn - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 94
All Time: 3,154
