Up to 20% off select tools
Amazon Luna Controller Shell Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
72
All Time:
604
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 - 40 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Over time, the buttons on your Amazon Luna gaming controller can wear out, become less responsive, or stop functioning entirely due to regular use, dirt buildup, or mechanical issues. To maintain optimal performance and extend the lifespan of your controller, it's essential to address these issues through proper cleaning, maintenance, or button replacement when needed. This guide offers a detailed, step-by-step process to safely remove and care for your controller's buttons. Following these instructions will help restore your device's functionality, ensuring a smoother gaming experience while preventing further damage during disassembly or repair.
    1. Amazon Luna Controller Shell Replacement, Battery: step 1, image 1 of 1
      • Flip the controller over so that the back panel is facing up.
      Ask FixBot
    2. Amazon Luna Controller Shell Replacement: step 2, image 1 of 3 Amazon Luna Controller Shell Replacement: step 2, image 2 of 3 Amazon Luna Controller Shell Replacement: step 2, image 3 of 3
      • Locate the latch on the back panel.
      • Pull down gently to open the compartment and expose the battery slots.
      • Remove batteries.
      Ask FixBot
    1. Amazon Luna Controller Shell Replacement, Faceplate: step 3, image 1 of 1
      • Flip the controller over to its front and locate the seam where the front plate connects to the rest of the body.
      Ask FixBot
    2. Amazon Luna Controller Shell Replacement: step 4, image 1 of 1
      • Hold the controller firmly.
      • Insert the thin edge of an iFixit opening tool into the seam at the edge of the front plate close to the A button.
      • Work slowly and carefully around all sides to avoid snapping the clips.
      Ask FixBot
    3. Amazon Luna Controller Shell Replacement: step 5, image 1 of 2 Amazon Luna Controller Shell Replacement: step 5, image 2 of 2
      • Once all clips are released, lift the front plate away from the controller.
      Ask FixBot
    1. Amazon Luna Controller Shell Replacement, Buttons: step 6, image 1 of 2 Amazon Luna Controller Shell Replacement, Buttons: step 6, image 2 of 2
      • Remove the six 8 mm screws securing the controller's body using a TR9 Torx screwdriver.
      Ask FixBot
    2. Amazon Luna Controller Shell Replacement: step 7, image 1 of 2 Amazon Luna Controller Shell Replacement: step 7, image 2 of 2
      • Gently pry along the seam that separates the two halves of the controller using an opening tool.
      • Work your way around the perimeter to carefully release the clips securing the two halves.
      Ask FixBot
    3. Amazon Luna Controller Shell Replacement: step 8, image 1 of 3 Amazon Luna Controller Shell Replacement: step 8, image 2 of 3 Amazon Luna Controller Shell Replacement: step 8, image 3 of 3
      • Lay the front of the controller shell downward.
      • Remove the rubber padding that keeps the buttons in place.
      • Remove the buttons from the shell housing.
      Ask FixBot
    1. Amazon Luna Controller Shell Replacement, Joystick Cover: step 9, image 1 of 2 Amazon Luna Controller Shell Replacement, Joystick Cover: step 9, image 2 of 2
      • Gently pull the joystick thumbstick straight up to remove it from the controller.
      Ask FixBot
    1. Amazon Luna Controller Shell Replacement, Shell: step 10, image 1 of 2 Amazon Luna Controller Shell Replacement, Shell: step 10, image 2 of 2
      • Gently grab the controller's circuitry and hold the bottom shell.
      • Pull the circuitry gently out from the shell.
      Ask FixBot
Author
with
Cade Queen
544 Reputation
5 Guides authored
2 Guide Comments
After putting it together, did your B button work again? I can't get mines to function anymore. The joysticks are also moving around a lot on their on.
SophisticatedCheese - Reply Share
I would check your reassembly and make sure none of the pads are damaged under the buttons
Ethan Phillips - Reply Share
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 72
All Time: 604
