Up to 20% off select tools
Amazon Luna Controller Buttons Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
93
All Time:
591
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 35 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
With extended use, the buttons on your Amazon Luna gaming controller may show signs of wear and tear, such as reduced sensitivity, sticking, or becoming completely unresponsive. These issues can arise from dirt and grime buildup, mechanical degradation, or prolonged exposure to pressure during gameplay. Addressing these problems through regular maintenance is essential to keeping your controller performing at its best and prolonging its overall lifespan.
    1. Amazon Luna Controller Buttons Replacement, Battery: step 1, image 1 of 1
      • Flip the controller over so that the back panel is facing up.
      Ask FixBot
    2. Amazon Luna Controller Buttons Replacement: step 2, image 1 of 3 Amazon Luna Controller Buttons Replacement: step 2, image 2 of 3 Amazon Luna Controller Buttons Replacement: step 2, image 3 of 3
      • Locate the latch on the back panel.
      • Pull down gently to open the compartment and expose the battery slots.
      • Remove batteries.
      Ask FixBot
    1. Amazon Luna Controller Buttons Replacement, Faceplate: step 3, image 1 of 1
      • Flip the controller over to its front and locate the seam where the front plate connects to the rest of the body.
      Ask FixBot
    2. Amazon Luna Controller Buttons Replacement: step 4, image 1 of 1
      • Hold the controller firmly.
      • Insert the thin edge of an iFixit opening tool into the seam at the edge of the front plate close to the A button.
      • Work slowly and carefully around all sides to avoid snapping the clips.
      Ask FixBot
    3. Amazon Luna Controller Buttons Replacement: step 5, image 1 of 2 Amazon Luna Controller Buttons Replacement: step 5, image 2 of 2
      • Once all clips are released, lift the front plate away from the controller.
      Ask FixBot
    1. Amazon Luna Controller Buttons Replacement, Buttons: step 6, image 1 of 2 Amazon Luna Controller Buttons Replacement, Buttons: step 6, image 2 of 2
      • Remove the six 8 mm screws securing the controller's body using a TR9 Torx screwdriver.
      Ask FixBot
    2. Amazon Luna Controller Buttons Replacement: step 7, image 1 of 2 Amazon Luna Controller Buttons Replacement: step 7, image 2 of 2
      • Gently pry along the seam that separates the two halves of the controller using an opening tool.
      • Work your way around the perimeter to carefully release the clips securing the two halves.
      Ask FixBot
    3. Amazon Luna Controller Buttons Replacement: step 8, image 1 of 3 Amazon Luna Controller Buttons Replacement: step 8, image 2 of 3 Amazon Luna Controller Buttons Replacement: step 8, image 3 of 3
      • Lay the front of the controller shell downward.
      • Remove the rubber padding that keeps the buttons in place.
      • Remove the buttons from the shell housing.
      Ask FixBot
Author
with
Cade Queen
544 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 93
All Time: 591
