Amazon Kindle Fire 7th Generation Battery Replacement
    1. Amazon Kindle Fire 7th Generation Battery Replacement, Loosen the back cover clips: step 1, image 1 of 3 Amazon Kindle Fire 7th Generation Battery Replacement, Loosen the back cover clips: step 1, image 2 of 3 Amazon Kindle Fire 7th Generation Battery Replacement, Loosen the back cover clips: step 1, image 3 of 3
      • Insert the plastic prying tool along the edge of the tablet, where the back cover meets the screen's bezel.
      • Carefully work your way around the edges to free all of the clips that secure the back cover in place.
      Ask FixBot
    2. Amazon Kindle Fire 7th Generation Battery Replacement, Remove the back cover: step 2, image 1 of 2 Amazon Kindle Fire 7th Generation Battery Replacement, Remove the back cover: step 2, image 2 of 2
      • Separate the back cover from the tablet.
      Ask FixBot
    3. Amazon Kindle Fire 7th Generation Battery Replacement, Remove the battery terminal cover: step 3, image 1 of 2 Amazon Kindle Fire 7th Generation Battery Replacement, Remove the battery terminal cover: step 3, image 2 of 2
      • Remove the two screws that secure the battery connector cover in place with a Phillips #00 screwdriver.
      • Lift the battery connector cover off.
      • Put the screws & battery connector cover aside for reassembly.
      Ask FixBot
    4. Amazon Kindle Fire 7th Generation Battery Replacement: step 4, image 1 of 2 Amazon Kindle Fire 7th Generation Battery Replacement: step 4, image 2 of 2
      • Disconnect the battery from the motherboard.
      • Fit the tip of the plastic opening tool under the bottom right of the battery.
      • Remove the battery from the frame.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 other people completed this guide.
Edgar Palomars
178 Reputation
1 Guide authored
CSU Los Angeles, Team 1-1, Briggs Fall 2023 Member of CSU Los Angeles, Team 1-1, Briggs Fall 2023
CSULA-BRIGGS-F23S1G1
6 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 148
All Time: 2,274
