Up to 20% off select tools
Amazon Kindle DX Previous Page Key Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
113
All Time:
2,174
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 35 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Parts
Tools
Introduction
Go to step 1 ↓
This guide shows you how to replace keyboard keys on an Amazon Kindle DX and uses the “previous page” key as an example. The “previous page” key has the less than symbol (<) on it and is located on the right side of the Amazon Kindle DX.
Prior to using this guide, test the keys to confirm that the keyboard is not working properly. To determine whether a key is faulty, press on the key to see if it performs the correct function. If not, the key is faulty. For example, when you press down on the “previous page” key of your Amazon Kindle DX and it doesn’t bring you to the previous page, the key is faulty.
This guide requires you to use the Phillips screwdriver, sizes PH0, PH00, and PH000, as well as a precision tweezer and opening tool. You must purchase a replacement key for the faulty key you are attempting to replace.
Before you begin, turn the Kindle off and unplug it from any external power source.
    1. Amazon Kindle DX Previous Page Key Replacement, Battery: step 1, image 1 of 1
      • Flip the Kindle so the back is facing upwards.
      Ask FixBot
    2. Amazon Kindle DX Previous Page Key Replacement: step 2, image 1 of 1
      • Push an opening tool against the bottom cover edge of the device. Move the tool's edge around the bottom plastic piece to pop it open.
      Ask FixBot
    3. Amazon Kindle DX Previous Page Key Replacement: step 3, image 1 of 1
      • Remove the plastic piece.
      Ask FixBot
    4. Amazon Kindle DX Previous Page Key Replacement: step 4, image 1 of 2 Amazon Kindle DX Previous Page Key Replacement: step 4, image 2 of 2
      • Remove two 40 mm screws (one on each corner) using a Phillips #00 screwdriver.
      Ask FixBot
    5. Amazon Kindle DX Previous Page Key Replacement: step 5, image 1 of 2 Amazon Kindle DX Previous Page Key Replacement: step 5, image 2 of 2
      • Use the edges of the opening tool, get in between the seams of the front and back panel, and use the tool to separate the pieces. Once loose, lift back panel off of the device.
      Ask FixBot
    6. Amazon Kindle DX Previous Page Key Replacement: step 6, image 1 of 2 Amazon Kindle DX Previous Page Key Replacement: step 6, image 2 of 2
      • Remove two 30 mm screws securing the battery with a Phillips #00 screwdriver.
      Ask FixBot
    7. Amazon Kindle DX Previous Page Key Replacement: step 7, image 1 of 2 Amazon Kindle DX Previous Page Key Replacement: step 7, image 2 of 2
      • Remove the battery from the device.
      Ask FixBot
    1. Amazon Kindle DX Previous Page Key Replacement, Previous Page Key: step 8, image 1 of 3 Amazon Kindle DX Previous Page Key Replacement, Previous Page Key: step 8, image 2 of 3 Amazon Kindle DX Previous Page Key Replacement, Previous Page Key: step 8, image 3 of 3
      • Remove five 30 mm screws from the midframe using a Phillips #000 screwdriver.
      Ask FixBot
    2. Amazon Kindle DX Previous Page Key Replacement: step 9, image 1 of 1
      • Remove the midframe to reveal the motherboard.
      Ask FixBot
    3. Amazon Kindle DX Previous Page Key Replacement: step 10, image 1 of 2 Amazon Kindle DX Previous Page Key Replacement: step 10, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the "previous page" button from the side function keys using a pair of tweezers.
      Ask FixBot
Author
with
Lori White
589 Reputation
3 Guides authored
USF Tampa, Team 1-5, Cagle Fall 2016 Member of USF Tampa, Team 1-5, Cagle Fall 2016
USFT-CAGLE-F16S1G5
3 Members
48 Guides authored
2 Guide Comments
The title says “keyboard”, this is button replacement…………….
Robert Clayworth - Reply Share
The title says “keyboard” replacement. This is button replacement…………….
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 113
All Time: 2,174
