Amazon Fire TV Cube Speaker Replacement
    1. Amazon Fire TV Cube Speaker Replacement, Speaker: step 1, image 1 of 3 Amazon Fire TV Cube Speaker Replacement, Speaker: step 1, image 2 of 3 Amazon Fire TV Cube Speaker Replacement, Speaker: step 1, image 3 of 3
      • Using a metal spudger, push down between the edge seals on the base and pry off the base.
      • Do not confuse the top thin layer of rubber with the thick palette that needs to be removed.
      • This may require substantial force.
      Ask FixBot
    2. Amazon Fire TV Cube Speaker Replacement: step 2, image 1 of 3 Amazon Fire TV Cube Speaker Replacement: step 2, image 2 of 3 Amazon Fire TV Cube Speaker Replacement: step 2, image 3 of 3
      • Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
      • There are 4 washers to go with each of the screws.
      Ask FixBot
    3. Amazon Fire TV Cube Speaker Replacement: step 3, image 1 of 1
      • Lift and remove the full frame.
      Ask FixBot
    4. Amazon Fire TV Cube Speaker Replacement: step 4, image 1 of 2 Amazon Fire TV Cube Speaker Replacement: step 4, image 2 of 2
      • Lift and remove the speaker.
      • Carefully match the outlets on the speaker with the outlets on the motherboard.
      Ask FixBot
2 other people completed this guide.
1 Guide Comment
Our volume pauses every 11 minutes! Troubleshooting our Sono’s System…still doing it. Could this be our Fire Cube?
Lee - Reply Share
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 30
All Time: 3,937
