Up to 20% off select tools
Amazon Fire Phone Micro-USB Port Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
95
All Time:
3,308
Comments: 9
7 comments on steps, 2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 minutes - 1 hour
Difficulty: Very difficult
Tools
Introduction
Go to step 1 ↓
Note that before removing the Micro-USB port you will need to remove the battery.
    1. Amazon Fire Phone Micro-USB Port Replacement, Tape the screen: step 1, image 1 of 1
      • If the display is damaged, use clear packing tape to contain any glass shards.
      • Make sure the entire surface of the display is covered with tape.
      • Wear safety glasses to protect your eyes.
      Ask FixBot
    2. Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: step 2, image 1 of 3 Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: step 2, image 2 of 3 Amazon Fire Phone Micro-USB Port Replacement, Power off, remove SIM card, remove screws: step 2, image 3 of 3
      • Power off your phone.
      • Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
      • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
      Ask FixBot
    3. Amazon Fire Phone Micro-USB Port Replacement: step 3, image 1 of 3 Amazon Fire Phone Micro-USB Port Replacement: step 3, image 2 of 3 Amazon Fire Phone Micro-USB Port Replacement: step 3, image 3 of 3
      • Press the small suction cup just above the home button.
      • While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
      • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
      • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
      Ask FixBot
    4. Amazon Fire Phone Micro-USB Port Replacement, Remove Bracket: step 4, image 1 of 1
      • Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
      • Remove the silver bracket that was held into place by the three screws just removed.
      Ask FixBot
    5. Amazon Fire Phone Micro-USB Port Replacement, Disconnect Battery: step 5, image 1 of 1
      • Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
      Ask FixBot
    1. Amazon Fire Phone Micro-USB Port Replacement, Micro-USB Port: step 6, image 1 of 2 Amazon Fire Phone Micro-USB Port Replacement, Micro-USB Port: step 6, image 2 of 2
      • Unscrew the 1mm screw on the top left side of the phone
      • Maneuver the bracket off slowly
      Ask FixBot
    2. Amazon Fire Phone Micro-USB Port Replacement: step 7, image 1 of 3 Amazon Fire Phone Micro-USB Port Replacement: step 7, image 2 of 3 Amazon Fire Phone Micro-USB Port Replacement: step 7, image 3 of 3
      • Disconnect the 9 cables along the top and right side of motherboard using the plastic opening tool
      Ask FixBot
    3. Amazon Fire Phone Micro-USB Port Replacement: step 8, image 1 of 1
      • Unscrew the 3mm screw located on the top left side of the phone with a flat head
      Ask FixBot
    4. Amazon Fire Phone Micro-USB Port Replacement: step 9, image 1 of 3 Amazon Fire Phone Micro-USB Port Replacement: step 9, image 2 of 3 Amazon Fire Phone Micro-USB Port Replacement: step 9, image 3 of 3
      • Unscrew the four 2mm screws along the right side of the motherboard with a philips head
      Ask FixBot
    5. Amazon Fire Phone Micro-USB Port Replacement: step 10, image 1 of 2 Amazon Fire Phone Micro-USB Port Replacement: step 10, image 2 of 2
      • Carefully lift up the motherboard and using the spudger pry camera from the camera holder
      Ask FixBot
    6. Amazon Fire Phone Micro-USB Port Replacement: step 11, image 1 of 1
      • Lift off bottom plastic piece with flat antenna cables
      Ask FixBot
3 other people completed this guide.
Author
with
Kent Kawahara
110 Reputation
1 Guide authored
Cal Poly, Team 5-7, Maness Fall 2015 Member of Cal Poly, Team 5-7, Maness Fall 2015
CPSU-MANESS-F15S5G7
5 Members
60 Guides authored
2 Guide Comments
Incomplete...
Indeedthis isaname - Reply Share
one missing pic in step 9. also any ideas where i can get a replacement part?
Yu Ryu - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 95
All Time: 3,308
