Amazon Fire Phone Headphone Jack Replacement
    1. Amazon Fire Phone Headphone Jack Replacement, Front Panel Assembly: step 1, image 1 of 1
      • If the display is damaged use clear packing tape to contain any glass shards.
      • Make sure the entire surface of the display is covered with tape.
      • Wear safety glasses to protect your eyes.
      Ask FixBot
    2. Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: step 2, image 1 of 3 Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: step 2, image 2 of 3 Amazon Fire Phone Headphone Jack Replacement, Preparation for Opening: step 2, image 3 of 3
      • Power off your phone.
      • Remove the sim card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
      • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
      Ask FixBot
    3. Amazon Fire Phone Headphone Jack Replacement, Manual Opening: step 3, image 1 of 3 Amazon Fire Phone Headphone Jack Replacement, Manual Opening: step 3, image 2 of 3 Amazon Fire Phone Headphone Jack Replacement, Manual Opening: step 3, image 3 of 3
      • Press the single suction cup just above the home button.
      • While lifting up on the suction cup place the plastic opening tool at the rim of the screen, separating the screen from the back casing.
      • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
      • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone, freeing the two halves.
      Ask FixBot
    4. Amazon Fire Phone Headphone Jack Replacement: step 4, image 1 of 3 Amazon Fire Phone Headphone Jack Replacement: step 4, image 2 of 3 Amazon Fire Phone Headphone Jack Replacement: step 4, image 3 of 3
      • Remove the 1mm screw concealed in the headphone jack.
      • Afterwards the headphone jack will easily pop off.
      Ask FixBot
3 other people completed this guide.
Savannah Moen
270 Reputation
1 Guide authored
1 Guide Comment
hello sir i need amazon fire back casing in Pakistan
Kashif Arif - Reply Share
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 106
All Time: 2,553
