Up to 20% off select tools
Amazon Fire Max 11 Micro SD Card Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
112
All Time:
1,467
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
A micro SD card is important when storing information on your device. This guide will explain how to install a micro SD card into your Amazon Fire Max 11 or replace an existing one if it is faulty or slow.
    1. Amazon Fire Max 11 Micro SD Card Replacement, Micro SD Card: step 1, image 1 of 1
      • Power off the device.
      Ask FixBot
    2. Amazon Fire Max 11 Micro SD Card Replacement: step 2, image 1 of 1
      • Press a SIM card tray pin (or a paper clip if you do not have the pin) into the hole in the side of the SIM card tray to eject the tray.
      Ask FixBot
    3. Amazon Fire Max 11 Micro SD Card Replacement: step 3, image 1 of 2 Amazon Fire Max 11 Micro SD Card Replacement: step 3, image 2 of 2
      • Remove the existing SIM card from the device.
      • Place the new SIM card in the slot of the SIM card tray in the direction indicated on the card.
      • Close the SIM card tray.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
Anthony Martins
522 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 112
All Time: 1,467
