Amazon Fire HD 8 Plus 12th Gen Speakers Replacement
    1. Amazon Fire HD 8 Plus 12th Gen Speakers Replacement, Rear Case: step 1, image 1 of 2 Amazon Fire HD 8 Plus 12th Gen Speakers Replacement, Rear Case: step 1, image 2 of 2
      • Unplug the charger, power down the device, and remove the SD card before beginning.
      • Insert an opening pick into the seam between the rear case and the screen assembly.
      • Slide the opening pick around the perimeter, prying periodically, until the screen assembly begins to release.
      • Insert an opening tool into the gap you created, and continue to pry periodically around the entire perimeter until the screen assembly fully releases.
      • Be patient and don't pry too hard in any specific place. Excessive force may cause damage to the device.
      Ask FixBot
    2. Amazon Fire HD 8 Plus 12th Gen Speakers Replacement: step 2, image 1 of 1
      • Remove the rear case.
      Ask FixBot
    1. Amazon Fire HD 8 Plus 12th Gen Speakers Replacement, Amazon Fire HD 8 Plus 12th Gen Battery Disconnection: step 3, image 1 of 1
      • Use an opening tool to lift the battery connector until it disconnects.
      Ask FixBot
    1. Amazon Fire HD 8 Plus 12th Gen Speakers Replacement, Amazon Fire HD 8 Plus 12th Gen Battery Disconnection: step 4, image 1 of 1
      Ask FixBot
    1. Amazon Fire HD 8 Plus 12th Gen Speakers Replacement, Speakers: step 5, image 1 of 3 Amazon Fire HD 8 Plus 12th Gen Speakers Replacement, Speakers: step 5, image 2 of 3 Amazon Fire HD 8 Plus 12th Gen Speakers Replacement, Speakers: step 5, image 3 of 3
      • Desolder the speaker motherboard connections.
      • Soldering can cause burns and fires. Always solder in a well-ventilated workspace.
      • Lift the speaker up and out of the chassis.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 16
All Time: 296
