Amazon Fire HD 8 Plus 12th Gen Motherboard Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
85
All Time:
940
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Difficult
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
If your kindle fire HD 8 12th generation is experiencing audio issues or getting stuck on the amazon logo screen upon startup, it may be caused by a hardware issue which can be fixed by replacing the motherboard
Tools
    1. Amazon Fire HD 8 Plus 12th Gen Motherboard Replacement, Rear Case: step 1, image 1 of 2 Amazon Fire HD 8 Plus 12th Gen Motherboard Replacement, Rear Case: step 1, image 2 of 2
      • Unplug the charger, power down the device, and remove the SD card before beginning.
      • Insert an opening pick into the seam between the rear case and the screen assembly.
      • Slide the opening pick around the perimeter, prying periodically, until the screen assembly begins to release.
      • Insert an opening tool into the gap you created, and continue to pry periodically around the entire perimeter until the screen assembly fully releases.
      • Be patient and don't pry too hard in any specific place. Excessive force may cause damage to the device.
      Ask FixBot
    2. Amazon Fire HD 8 Plus 12th Gen Motherboard Replacement: step 2, image 1 of 1
      • Remove the rear case.
      Ask FixBot
    1. Amazon Fire HD 8 Plus 12th Gen Motherboard Replacement, Amazon Fire HD 8 Plus 12th Gen Battery Disconnection: step 3, image 1 of 1
      • Use an opening tool to lift the battery connector until it disconnects.
      Ask FixBot
    1. Amazon Fire HD 8 Plus 12th Gen Motherboard Replacement, Battery: step 4, image 1 of 1
      • Gently and slowly grip and pull the three white adhesive tabs that secure the battery until they fully release.
      • The adhesives are marked with a black flap with a white adhesive. You will know it has been successfully removed when you can move the battery around.
      Ask FixBot
    2. Amazon Fire HD 8 Plus 12th Gen Motherboard Replacement: step 5, image 1 of 3 Amazon Fire HD 8 Plus 12th Gen Motherboard Replacement: step 5, image 2 of 3 Amazon Fire HD 8 Plus 12th Gen Motherboard Replacement: step 5, image 3 of 3
      • Gently pry around the entire perimeter of the battery with an opening tool until the adhesive releases.
      • Remove the battery.
      • Take care not to bend or puncture the battery while prying the battery.
      • Clean under the old battery and insert a new battery with adhesive to ensure the battery stays in place.
      Ask FixBot
    1. Amazon Fire HD 8 Plus 12th Gen Motherboard Replacement, Motherboard: step 6, image 1 of 2 Amazon Fire HD 8 Plus 12th Gen Motherboard Replacement, Motherboard: step 6, image 2 of 2
      • Lift the black ZIF locking flap.
      • Disconnect the ribbon cable.
      Ask FixBot
    2. Amazon Fire HD 8 Plus 12th Gen Motherboard Replacement: step 7, image 1 of 3 Amazon Fire HD 8 Plus 12th Gen Motherboard Replacement: step 7, image 2 of 3 Amazon Fire HD 8 Plus 12th Gen Motherboard Replacement: step 7, image 3 of 3
      • Remove all of the Phillips screws that secure the motherboard.
      Ask FixBot
    3. Amazon Fire HD 8 Plus 12th Gen Motherboard Replacement: step 8, image 1 of 3 Amazon Fire HD 8 Plus 12th Gen Motherboard Replacement: step 8, image 2 of 3 Amazon Fire HD 8 Plus 12th Gen Motherboard Replacement: step 8, image 3 of 3
      • Desolder all of the soldered motherboard connections.
      • Soldering can cause fires and burns. Always solder in a well-ventilated workspace.
      Ask FixBot
    4. Amazon Fire HD 8 Plus 12th Gen Motherboard Replacement: step 9, image 1 of 1
      • Lift the motherboard up and out of the chassis.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 85
All Time: 940
