Amazon Fire HD 8 Plus 12th Gen Battery Replacement
    1. Amazon Fire HD 8 Plus 12th Gen Battery Replacement, Rear Case: step 1, image 1 of 2 Amazon Fire HD 8 Plus 12th Gen Battery Replacement, Rear Case: step 1, image 2 of 2
      • Unplug the charger, power down the device, and remove the SD card before beginning.
      • Insert an opening pick into the seam between the rear case and the screen assembly.
      • Slide the opening pick around the perimeter, prying periodically, until the screen assembly begins to release.
      • Insert an opening tool into the gap you created, and continue to pry periodically around the entire perimeter until the screen assembly fully releases.
      • Be patient and don't pry too hard in any specific place. Excessive force may cause damage to the device.
      Ask FixBot
    2. Amazon Fire HD 8 Plus 12th Gen Battery Replacement: step 2, image 1 of 1
      • Remove the rear case.
      Ask FixBot
    1. Amazon Fire HD 8 Plus 12th Gen Battery Replacement, Amazon Fire HD 8 Plus 12th Gen Battery Disconnection: step 3, image 1 of 1
      • Use an opening tool to lift the battery connector until it disconnects.
      Ask FixBot
    1. Amazon Fire HD 8 Plus 12th Gen Battery Replacement, Battery: step 4, image 1 of 1
      • Gently and slowly grip and pull the three white adhesive tabs that secure the battery until they fully release.
      • The adhesives are marked with a black flap with a white adhesive. You will know it has been successfully removed when you can move the battery around.
      Ask FixBot
    2. Amazon Fire HD 8 Plus 12th Gen Battery Replacement: step 5, image 1 of 3 Amazon Fire HD 8 Plus 12th Gen Battery Replacement: step 5, image 2 of 3 Amazon Fire HD 8 Plus 12th Gen Battery Replacement: step 5, image 3 of 3
      • Gently pry around the entire perimeter of the battery with an opening tool until the adhesive releases.
      • Remove the battery.
      • Take care not to bend or puncture the battery while prying the battery.
      • Clean under the old battery and insert a new battery with adhesive to ensure the battery stays in place.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Make sure you have a applied a adhesive for the new battery to make sure it stays in place.
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 23
Past 30 Days: 92
All Time: 736
