Up to 20% off select tools
Amazon Fire HD 8 Front Camera Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
100
All Time:
2,665
Comments: 9
9 comments on steps.
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
In this guide, we will show you how to replace the front camera. Before you start, make sure your device is powered off.
    1. Amazon Fire HD 8 Front Camera Replacement, Screen: step 1, image 1 of 2 Amazon Fire HD 8 Front Camera Replacement, Screen: step 1, image 2 of 2
      • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
      • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
      Ask FixBot
    2. Amazon Fire HD 8 Front Camera Replacement: step 2, image 1 of 1
      • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
      • Be careful not to bend the screen by pushing it too far from the rest of the device.
      Ask FixBot
    3. Amazon Fire HD 8 Front Camera Replacement: step 3, image 1 of 3 Amazon Fire HD 8 Front Camera Replacement: step 3, image 2 of 3 Amazon Fire HD 8 Front Camera Replacement: step 3, image 3 of 3
      • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
      • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
      Ask FixBot
    4. Amazon Fire HD 8 Front Camera Replacement: step 4, image 1 of 3 Amazon Fire HD 8 Front Camera Replacement: step 4, image 2 of 3 Amazon Fire HD 8 Front Camera Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
      Ask FixBot
    1. Amazon Fire HD 8 Front Camera Replacement, Front Camera: step 5, image 1 of 3 Amazon Fire HD 8 Front Camera Replacement, Front Camera: step 5, image 2 of 3 Amazon Fire HD 8 Front Camera Replacement, Front Camera: step 5, image 3 of 3
      • Using a T4 screwdriver, remove the two screws situated on the left and right side of the camera.
      • The gasket may pop out, but it can easily be put back in.
      Ask FixBot
    2. Amazon Fire HD 8 Front Camera Replacement: step 6, image 1 of 2 Amazon Fire HD 8 Front Camera Replacement: step 6, image 2 of 2
      Buy
      • Using tweezers, gently remove the white tape with the QR code.
      • Fold the camera back and use tweezers to gently remove the orange tab.
      Ask FixBot
Author
with
Dan Shimkus
1,238 Reputation
3 Guides authored
USF Tampa, Team 1-3, Leahy Spring 2016 Member of USF Tampa, Team 1-3, Leahy Spring 2016
USFT-LEAHY-S16S1G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 100
All Time: 2,665
