Amazon Fire HD 8 Bottom Speaker Replacement
    1. Amazon Fire HD 8 Bottom Speaker Replacement, Screen: step 1, image 1 of 2 Amazon Fire HD 8 Bottom Speaker Replacement, Screen: step 1, image 2 of 2
      • Heat the edges of the screen with a heat gun on the lowest setting by using sweeping motions from about 8-10 inches away.
      • Make sure you use sweeping motions with the heat gun, instead of hovering over one area.
      Ask FixBot
    2. Amazon Fire HD 8 Bottom Speaker Replacement: step 2, image 1 of 1
      • After 1-2 minutes, use a plastic opening tool to pry the screen loose. Start at the top right corner and gently pry the screen from the device.
      • Be careful not to bend the screen by pushing it too far from the rest of the device.
      Ask FixBot
    3. Amazon Fire HD 8 Bottom Speaker Replacement: step 3, image 1 of 3 Amazon Fire HD 8 Bottom Speaker Replacement: step 3, image 2 of 3 Amazon Fire HD 8 Bottom Speaker Replacement: step 3, image 3 of 3
      • Slide a plastic opening tool and spudger along the underside of the screen using enough force to peel the screen and the adhesive strip from the other half of the device.
      • Be mindful of the orange cable connecting the screen to the mid-bottom of the device.
      Ask FixBot
    4. Amazon Fire HD 8 Bottom Speaker Replacement: step 4, image 1 of 3 Amazon Fire HD 8 Bottom Speaker Replacement: step 4, image 2 of 3 Amazon Fire HD 8 Bottom Speaker Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • To remove the screen from the device, use tweezers to gently pull the orange cable from its connection to the screen.
      Ask FixBot
    1. Amazon Fire HD 8 Bottom Speaker Replacement, Bottom Speaker: step 5, image 1 of 1
      Buy
      • Using tweezers, carefully lift the copper strip from the right side of the speaker.
      Ask FixBot
    2. Amazon Fire HD 8 Bottom Speaker Replacement: step 6, image 1 of 2 Amazon Fire HD 8 Bottom Speaker Replacement: step 6, image 2 of 2
      • Remove the two screws located on the top left and bottom right of the speaker using a T4 screwdriver.
      Ask FixBot
    3. Amazon Fire HD 8 Bottom Speaker Replacement: step 7, image 1 of 1
      • Lift the right side of the speaker and carefully unhook and remove it from the device.
      • Be mindful of the white wire connecting the speaker to the device.
      Ask FixBot
    4. Amazon Fire HD 8 Bottom Speaker Replacement: step 8, image 1 of 2 Amazon Fire HD 8 Bottom Speaker Replacement: step 8, image 2 of 2
      • Set aside the black speaker and follow the white wire to its connection on the upper left side of the motherboard.
      • Using tweezers, gently pry the black clip upward from the board.
      Ask FixBot
Marisa Holste
695 Reputation
1 Guide authored
USF Tampa, Team 1-3, Leahy Spring 2016 Member of USF Tampa, Team 1-3, Leahy Spring 2016
USFT-LEAHY-S16S1G3
4 Members
60 Guides authored
1 Guide Comment
I would like to ask if you happen to know the part number of the speaker and where I could acquire said device?
Thank you a very helpful walk-through guide
Keven Paxton - Reply Share
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 100
All Time: 5,100
