Amazon Fire HD 7 (4th Generation) Rear facing camera replacement
    1. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: step 1, image 1 of 3 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: step 1, image 2 of 3 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement, Rear-facing camera: step 1, image 3 of 3
      • Insert the plastic opening tool behind the rear case to free the clips holding the case together.
      • Work your way around the device to free all the clips.
      Ask FixBot
    2. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: step 2, image 1 of 1
      • There are an additional nine clips surrounding the battery area. Place the plastic tool into the clips and lift to disconnect them.
      • Once all clips have been released, the back case can be pulled free to reveal the inside of the device.
      Ask FixBot
    3. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: step 3, image 1 of 1
      • Use a nylon spudger to unclip the connection from the motherboard.
      Ask FixBot
    4. Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: step 4, image 1 of 2 Amazon Fire HD 7 (4th Generation)  Rear facing camera replacement: step 4, image 2 of 2
      • Unscrew the two screws using a T5 screwdriver.
      • The camera lens are sensitive. Be careful when removing and handling camera.
      • Once freed from the screws, gently lift and remove the camera.
      Ask FixBot
Omir Rosado
752 Reputation
5 Guides authored
USF Tampa, Team 4-4, Passmore Fall 2016 Member of USF Tampa, Team 4-4, Passmore Fall 2016
USFT-PASSMORE-F16S4G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 106
All Time: 1,087
